Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-09-2009, 12:45 PM   #1
2GOFAST
CF Senior Member
2GOFAST's Avatar
Default What are the symptoms of a faulty thermostat?
I think my thermostat is failing to open as my coolant temp is getting very high. It started all of a sudden about a week ago and my coolant temp is getting up to 240-245F on a regular basis while it used to average around 210-220F. Note - it is fall/winter here with outside temps typically at a high of 50F. Also, my fans are running and the coolant level appears good (about 1/2 of overflow tank is full when the system is cold).
So, what are the symptoms of a faulty thermostat?
2GOFAST
2GOFAST is offline   Reply With Quote
Old 11-09-2009, 12:50 PM   #2
Eric D
St. Jude Donor '09-'10-'11
Support Corvetteforum!
Eric D's Avatar
More than likely your problem is road dirt, leaves, grass, and small stones and like things plugging the front side of the radiator. When is the last time it was cleaned?
Eric D is offline   Reply With Quote
Old 11-09-2009, 01:11 PM   #3
2GOFAST
CF Senior Member
2GOFAST's Avatar
Quote:
Radiator is clean - put the car on ramps and looked at it yesterday.
Thanks for the suggestion though.
Old 11-09-2009, 01:27 PM   #4
dougbfresh
CF Senior Member
Pull the t-stat and put it on the stove in water with a thermometer, you'll know in less than 5 minutes if it opens when it's supposed to. Factory T-stats FAIL CLOSED, you'll know quickly if it's failed.
dougbfresh is offline   Reply With Quote
Old 11-09-2009, 01:30 PM   #5
Eric D
Eric D's Avatar
Has the coolant system been open recently? Having entrapped air will cause what you described.
Old 11-09-2009, 02:19 PM   #6
2GOFAST
CF Senior Member
2GOFAST's Avatar
Here is some more information. The coolant system was not opened prior to the problem ocurring - in fact it had not been opened since my H/C install 1-1/2 years ago. I drained the radiator and pulled the thermostat yesterday, played around with it by hand and then put it in boiling water and got it to cycle open and closed. I put it back in the car and followed the service manual for refilling the coolant and running at 2500+rpms for awhile follwed by 3 minutes of idling. It worked great and my max temp was about 215F during a 15 minute drive at 2500+rpm.
This morning, however, the temp has again spiked to higher than normal (240-245F) and it appears that the same thing is happening again.
So, I am thinking that maybe the thermostat is sticking closed and that my playing with it only temporarily fixed it.
But, back to my original question - What are the symptoms of a bad thermostat???
Old 11-09-2009, 04:34 PM   #7
dougbfresh
CF Senior Member
AGAIN, they fail CLOSED-you would OVERHEAT QUICKLY. The only REAL way to tell is the hot water test with a thermometer. You can also use an IR thermometer to see how hot the hoses are. Are the Fans coming on correctly?
Old 11-09-2009, 05:28 PM   #8
wcsinx
CF Senior Member
wcsinx's Avatar
Quote:
You overheat.
Why would you stick an old $10 thermo back in your car? That's one of those parts that I don't even dick with diagnosing. If it's torn down to that point and drained, then put a new one in.
If the fans are coming on when they're supposed to, then you've probably got a clogged radiator. I know you say you looked at it, but you know what? I looked at mine too before I blasted it out, and it looked fine but I bet I got 2 cups of sand out of that damned thing.
wcsinx is online now   Reply With Quote
Old 11-10-2009, 11:20 AM   #9
c3andc5
CF Senior Member
c3andc5's Avatar
Symptoms of a bad t-stat are:
1. Overheating due to t-stat not opening.
2. Coolant not coming up to proper temp due to t-stat stuck open.
If you checked it and it opened/closed then I would suspect the fans aren't coming on
OR
Your radiator is clogged.
OR
Your coolant level is too low.
OR
Radiator hose is collapsed.
Does the temp rise higher then normal while you are driving or when you are at idle (not moving)?
Next time you go to the trouble to remove and check a t-stat, recommend you just put in a new one.
__________________
2000 Torch Red Coupe
c3andc5 is offline   Reply With Quote
Old 11-10-2009, 12:19 PM   #10
2GOFAST
CF Senior Member
2GOFAST's Avatar
Thanks for the responses. FYI - I have a 160F thermostat and have to order one to get a replacement - thus the reason I did not change it out when I opened up the system.
I will work through the list. Maybe my fans are only operating on low and not high speed.
As for the temp - it is higher during idle and only drops a little bit when driving - I suppose it is a fight between greater heat production due to combustion and the higher airflow over the block due to driving. The service manual indicates that the cooling system is only designed to remove some (about 1/3 - I forget the exact #) of the heat of combustion.
Old 11-10-2009, 03:39 PM   #11
c3andc5
CF Senior Member
c3andc5's Avatar
Lots of debate over the advantages and disadvantages of not using a stock (187 deg) t-stat. Personally, that's one of the things I'd keep stock. Good luck chasing down your problem.
__________________
Old 11-10-2011, 09:17 PM   #12
BB2000C5
Junior Member
Please Help!!
Have a 2000 C5, had some coolant loss because of a cut hose. I had the hose replaced but I was told that the Dexicool causes crystalization in the radiator. The engine is still running hotter than usual. it was running about 199 to 240 until I started driving then it would cool back down. Now it seems to be running hotter at highway speeds and will cool down as I slow the car down until I come to an idle then back up. Is this the thermostat? The radiator? or something else? Any advise would be appreciated due to mechanics just wanting to replace everything.
BB2000C5 is offline   Reply With Quote
Reload this Page What are the symptoms of a faulty thermostat?
Tags
bad, bios, c5, car, clogged, closed, coming, corvette, failed, fan, faulty, open, replace, sticking, stuck, symptoms, thermostat
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Help needed! Could faulty coil cause this?? jutammel C4 Tech/Performance 10 10-11-2003 04:30 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
