Front end to low
Old 11-08-2011, 09:42 AM
JBC
7th Gear
JBC's Avatar
Default Front end to low
My front end sets to low which causes the headlights to point to the ground. Dealer set the lights to the spec adjustments.
What is the proper height off the ground and what might cause this?
Old 11-08-2011, 11:23 AM
dougbfresh
dougbfresh's Avatar
Somebody before you (or maybe you) lowered the cars suspension.
Old 11-08-2011, 01:56 PM
JBC
7th Gear
JBC's Avatar
1999- Bought it with 3 miles and haven't done anything, it's been this way a few years. Can't figure it out.
Old 11-08-2011, 02:22 PM
m6 c5
m6 c5's Avatar
Have you tried adjusting your headlights yourself and aiming them further up?
Old 11-08-2011, 02:34 PM
cdkcorvette7
cdkcorvette7's Avatar
Pic of the side profile of the car please. If you haven't altered your ride height and you have owned it since it had 3 miles on it chances are your height is fine and your headlights need adjusting...
Old 11-08-2011, 02:42 PM
gotz06?
gotz06?'s Avatar
I agree
Old 11-08-2011, 07:31 PM
lionelhutz
lionelhutz's Avatar
#1 - The stock headlights are fairly crappy so don't expect good light from them.
#2 - Why would you believe your car is too low in the front if you have owned it from new? The only reason it would drop is if you broke the front spring and I sure as hell hope both you and the dealer would catch something as obvious as that.
Peter
Old 11-08-2011, 08:00 PM
C5FORFUN2
C5FORFUN2's Avatar
Never too low, the backs just too high
Old 11-09-2011, 07:22 PM
RaW Z06
RaW Z06's Avatar
That's what I was thinking!
Old 11-09-2011, 08:52 PM
JBC
7th Gear
JBC's Avatar
My point is the front end sets lower than other C5 in my club. I was in a parking lot side by side with about 5-6 other C5s and noticed mine sat lower, I measured and it is. Don't
know why, but I would like a stright answer if possible. I don't want to go to my dealer
if possible. Just thought someone might have run into this or know someone who has.
Old 11-09-2011, 10:37 PM
m6 c5
m6 c5's Avatar
If you really want you can raise the front by adjusting the ride height bolts but I would imagine you could just adjust your headlights up.
Old 11-09-2011, 10:40 PM
lionelhutz
lionelhutz's Avatar
A broken front spring...
Old 11-09-2011, 10:48 PM
m6 c5
m6 c5's Avatar
Thats a possibility but it seems like he would be slammed in the front or it to be higher on one side or another. Plus Im pretty sure he said he took it to the dealer and you would think they would have caught that...
Old 11-10-2011, 12:51 AM
printmanjackson
printmanjackson's Avatar
St. Jude Donor '06-'07-'08-'09
check the rake in the frame height and if it's got too much just lower the rear. Should be about 1/8" with a full tank of fuel
Old 11-10-2011, 06:48 AM
leadfoot4
leadfoot4's Avatar
Received 1,343 Likes on 1,094 Posts
My point is the front end sets lower than other C5 in my club. I was in a parking lot side by side with about 5-6 other C5s and noticed mine sat lower, I measured and it is. Don't know why, but I would like a straight answer if possible. I don't want to go to my dealer if possible. Just thought someone might have run into this or know someone who has.
If you want a "straight answer', you need to provide a little more specific information, such as the height from the ground to the top of the wheel openings, front and rear. It's not the most precise point of measurement, but it's a least a point of reference. A side picture of your car would be even better.
Secondly, at what point did your headlights become "aimed too low"? Headlights generally don't just drop out of adjustment, unless the rubber bushing "stops" on the headlight assemblies have aged and crumbled...
Old 11-10-2011, 09:11 PM
Jewjenk
Jewjenk's Avatar
You say you had the car since practically brand new. Then there was a point at which the front dropped. So either you are or you abused the car or the front spring has broke, thus slamming the car. If you provide enough info, then someone will help. If you are into so much privacy, then this isn't the place, take the car to a dealer..............
Old 11-10-2011, 09:14 PM
Jewjenk
Jewjenk's Avatar
Hmmmmmmmmmm, been that way for a few years now? So why worry about it now..................................... ....Take a few pictures and post em................
To Front end to low
Quick Reply: Front end to low
