Stock air bridge
Stock air bridge
how restrictive is it? i was thinking of getting a smooth bellow for it becuase i dont like any of the aftermarket airbridges, but i heard that when converting to a ls2 tb the aftermarket bellow is to short
I recall past threads that said the oem air bridge is more than capable of handling horsepower well over 400hp. People change them for the "bling" which is fine if form over function is your goal.
Some over sized air bridges may interfere with your hood insulator and/or how well your hood closes. After market air bridges also do not have the ears to secure the air bridge to the radiator cover. So, the air bridge and air cleaner assembly weight is just hanging from the throttle body.
I think it was LINGENFELTER that used the oem air bridge in his cars.
You can improve the looks of the oem air bridge with paint or decals.
now its between these three to get rid of the accordion coupler
http://www.slponline.com/view_product.asp?P=23066
http://www.westcoastcorvette.com/p-3...oupler-c5.aspx
http://www.customcorvetteaccessories...rcouplers.html
I got rid of it and bought the SLP coupler with the bump. That didn't need to be cut and the bump allowed for just enough flexibility like the oem accordion coupler. I don't think it comes in any color other than black though.
Stock air bridge
If you measure the cross section area of the stock air bridge you will find that the squeshed middle parts area is still larger than what it connects to at each end.
