Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-23-2009, 01:35 PM   #21
Nd4spd2
CF Senior Member
St. Jude Donor '08
Nd4spd2's Avatar
Great info, thanks
Nd4spd2 is offline   Reply With Quote
Old 11-24-2009, 07:08 AM   #22
FourG63 97GST
CF Senior Member
FourG63 97GST's Avatar
Send a message via AIM to FourG63 97GST
I love you man, I miss my HUD.
FourG63 97GST is online now   Reply With Quote
Old 08-22-2010, 04:53 PM   #23
Nosferatu333
CF Senior Member
Excellent write up!
Alas, I cannot complete as just my luck. THe plastic piece of the other side is broken too! So the mirror kinda moves around a bit. Dont want to install it like that only to have to redo it in the future.
Any known fixes. Can i at least buy a replacement piece? Part number anyone?
Thanks for any and all input.
Nosferatu333 is offline   Reply With Quote
Old 08-22-2010, 05:26 PM   #24
00Corvette
CF Senior Member
00Corvette's Avatar
excellent write up man! thread saved!
00Corvette is offline   Reply With Quote
Old 08-22-2010, 07:03 PM   #25
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Support Corvetteforum!
Bill Curlee's Avatar
Quote:
Originally Posted by Nosferatu333 View Post
Excellent write up!
No one sells repair parts for the intarnals. Just the entire HUD.
BC
Bill Curlee is offline   Reply With Quote
Old 08-23-2010, 12:12 AM   #26
brendan.9
CF Senior Member
brendan.9's Avatar
Send a message via MSN to brendan.9
will be doing this soon and the same as the climate control!
brendan.9 is offline   Reply With Quote
Old 08-29-2010, 10:30 PM   #27
FirethornC5
CF Senior Member
FirethornC5's Avatar
Excellent write up!
First off I have to thank KCJeff for posting the fix for the broken pin. I just purchased a used projector and it had the broken pin problem too. And, I believe someone was already in the projector and took the plastic clip from the opposite side. So, I figured a way to fix that side and here it is. I used a wire grommet.
Here's some pics & descriptions of what I did:
FirethornC5 is offline   Reply With Quote
Old 09-09-2010, 04:13 PM   #28
04 commemorative
CF Senior Member
04 commemorative's Avatar
I would freak out if I had to remove the dash...
04 commemorative is offline   Reply With Quote
Old 10-21-2010, 07:18 AM   #29
biglite351
CF Senior Member
biglite351's Avatar
Send a message via Yahoo to biglite351
Do you HAVE to remove the dash or is this something that you can fix from the top?
biglite351 is offline   Reply With Quote
Old 11-01-2010, 04:25 PM   #30
Corvette ED
CF Senior Member
Corvette ED's Avatar
Location: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
You have to remove the dash pad. I can do the whole job in and out in less than three hours.
Corvette ED is offline   Reply With Quote
Old 11-27-2010, 08:02 PM   #31
caribracer
Junior Member
caribracer's Avatar
Default Re: DIY fix for the dreaded falling HUD
Absolutely awesome post for this problem. Great pictures as well. I appreciate your time and effort. I will be pulling my dash pad and correcting my display next weekend. Thank you for your help!!!
caribracer is offline   Reply With Quote
Old 12-04-2010, 02:45 PM   #32
prseasix
CF Senior Member
prseasix's Avatar
Location: NW Fla - Take it easy on 06ama- it's his first job!
Good post- HUD pin fix
prseasix is offline   Reply With Quote
Old 12-04-2010, 08:55 PM   #33
TEXHAWK0
CF Senior Member
TEXHAWK0's Avatar
Wondering if the screw threads will cut into the housing over time. It might be worth finding a plastic sleeve to go over the screw threads if there is enough clearance.
TEXHAWK0 is offline   Reply With Quote
Old 04-16-2011, 11:34 PM   #34
wwnf
Junior Member
Just fixed my HUD with the help of this thread. Took me 5 hours, first time removing anything on a Corvette. I forgot to cover the steering wheel with a towel or something so I scratched it a little bit while removing the dash. I was sad to see what I had done but with the HUD actually visible while driving, I quickly forgot.
Thanks!!!
wwnf is offline   Reply With Quote
Old 04-17-2011, 07:15 PM   #35
ALLEGRO
CF Senior Member
ALLEGRO's Avatar
I admire the bravery for even trying to fix something like this. Congratuations and bravo on your success.
__________________
2003 50th ANNIVERSARY EDITION
CLICK PICTURES TO ENLARGE
ALLEGRO is offline   Reply With Quote
Old 06-25-2011, 07:56 PM   #36
caribracer
Junior Member
caribracer's Avatar
Default Thanks for the HUD Repair info
I just completed the fix an hour ago and I have to tell you, I wouldn't have had any idea that I could have fixed the problem so easy without your post! I did the complete job in 5 hours and that wasn't getting in a hurry. I sincerely appreciate the article you wrote and the time you took to take pictures and showing the problem in such detail. I owe the same debt of gratitude to (at88mph) for his informative and detailed article on the disassembly of the console and dash. Anyone that hasn't tackled a project like this has no idea how informative and helpful both your articles are. Thanks to you my HUD is now working perfectly again!!!
Old 08-01-2011, 07:01 AM   #37
dyoes
Junior Member
Default Fantastic!
Great post. I replaced my stereo yesterday and decided to tackle the HUD while I had the interior torn apart. Also took the opportunity to install silver trim rings around the gauges.
Very easy to do if you are at all mechanically inclined. The dash came apart very easily. Thanks to the repair instructions here, the HUD went back together just fine and now works great.
One thing I'd offer. When you reinstall the mirror, make sure that it moves freely through its range of motion. You can see the gear travel limit switches in the pics. The gear on the mirror mount has to be installed at the right place or it won't travel. If you can't move it by hand (easily) from one limit switch to the other, take out and try again, changing the gear position until you get it right.
Also, try everything out before you reinstall the dash to make sure it works.
Good luck!
Darryl
2004 Black/Black coupe
1974 Black/Black coupe
dyoes is offline   Reply With Quote
Old 09-04-2011, 10:44 PM   #38
kidwell03
Junior Member
Good luck!
Darryl
1st Off thanks for the post brought my HUD back to life today!
Followed the instructions to a T went outside reinstalled the HUD nothing. Came back read the quote above followed recommendation and it worked!! Thanks
kidwell03 is offline   Reply With Quote
Old 09-05-2011, 11:32 AM   #39
ricknyc23
CF Senior Member
ricknyc23's Avatar
anyone on Long Island or close that wants to repair mine? No way Im going to be able to do it myself....PM me if you can help....
Thanks....
ricknyc23 is offline   Reply With Quote
Old 09-05-2011, 11:39 AM   #40
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Quote:
Thanks....
Contact Forum Member " STEVE DOTEN " He is the resident HUD EXPERT and lives here in North East CT. Im sure that he can help you.
Thats his forum Name also..
Bill Curlee
Reload this Page DIY Fix for the dreaded Falling HUD Display
Tags
2004, 2005, adjustment, c5, corvette, display, diy, dropping, falls, fix, hud, projected, removal, spring, vette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
