cracked rear rims
cracked rear rims
Took tires off my 2001 vette and see small cracks starting from the outside working there way in. About 4 or 5 per wheel.
These are speedline rims.
Question is - not sure how long they have been there or if will they get worse. How much should I worry about them. Should I mount new tires to them, I dont race or go faster than hiway speeds.
I would of never known till the tires came off.
What do you think.
What do you think.
How many people riding around with cracked thin spoke rims, bet there are lots. Never would of known as they are small and on inside of rear rims only but they are through the thickness of the rim.
Question is - should I be worried, how many with speedline rims have actually blown apart?
Excuse me, you have wheels cracked THROUGH the rims at FOUR OR FIVE PLACES PER WHEEL and you want to know "how many with speedline rims have actually blown apart?" !!!!!
DON'T USE THE WHEELS UNLESS YOU WANT TO COMMIT SUICIDE.
I would of never known if they were on the car.
Cracked Rim Pix, questions, & WTB
1.) WTB 50th Anniversary front rim. Any sellers?
2.) One crack as shown. Anybody ever have one repaired?
3.) These are aluminum alloy, right?
4.) Would TIG repair would be best?
5.) Repaired rim acceptable for grandpa street use?
6.) Do you think the crack was created when the rim weight was hamered on?
I would think hitting a pot hole could cause a rim to crack like that. Install or removal of balance weights would not have caused the crack. You really need to replace that wheel, LIKE YESTERDAY! Good luck.
Seen pics before of the aftermath of rims blowing apart (this was at the lug nut area and not on a vette), it was not pretty , get some new rims from JW Motoring, he has the best deals around.
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Ahhhhhh,, A little ZAINO and a buff job and you will never see that crack! UNTIL THE WHEEL BLOWS APART!
I see new wheels in your future!
OMG I wouldn't drive that wheel 5 feet
I had a slow leak on one of my wagon wheels. Couldn't see anything looking at the wheel from the outside. Demounted wheel and saw crack on inside rim. Immediately replaced it and checked all other wheels too.
I've had blowouts and a steel wheel rust thru and actually fail with the car PARKED. Being lucky is better than being stupid and driving on something which can cost your and others lives. Get scrap value for the aluminum after replacing any and all cracked wheels no matter how small the cracks are.
Remember the Electras? Tails fell off from metal fatigue.
Ditch those wheels before you land in the hospital or worse.
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Grand Pa driving What happens when your grand pa driving at 70 mph and you have to swerve to avoid an accident and the wheel self destructs?
Be careful.
BC
Cracked Rim Repair
See rim repair pix. One crack:
$20 - Break, remount, balance tire
$40 - Rim repair. Cut slot, TIG weld, rough grind, spray paint. (For show, more grinding, sanding, & painting would be required).
This repair should hold. I will post if any problems in future.
Don not drive on a rim like that I can send you the pics of my cousins crash he ended splitting his car in 2 on a post when he lost control
