Cooling Fans-when should they come on?
Old 10-12-2009, 08:13 PM
8th Gear
210007587's Avatar
Default Cooling Fans-when should they come on?
I have a 1998 C5: It appears that the passenger side fan comes on only when the AC compressor is on. The drivers side is what I'm not understanding- sometimes comes on when the engine is cold. Can someone tell me when it should come on? What temp? Thanks
Onthat_Z06 (08-14-2019)
Old 10-12-2009, 10:49 PM
byronhunter
byronhunter's Avatar
OK
Old 10-12-2009, 11:00 PM
Its_Go_Time
Its_Go_Time's Avatar
Originally Posted by 8VETTE7
If you have only one fan running then you have a problem that needs to be diagnosed. When the fans run both run at the same time at either high speed or low speed.
I agree. The fans are wired in a series/parellel configuration. When they're running in parallel, they turn fast. When is series, they turn slow. They always turn together.
I would start from the motors and work back. Both motors seem to work, so maybe one of the relays are shot. Probe the relay sockets and make sure the pcm is trying to energize them, and check that they are actually switching.
Old 10-13-2009, 04:46 PM
8th Gear
210007587's Avatar
Great information. Thanks very much.
Old 10-13-2009, 08:22 PM
Oldvetter
Oldvetter's Avatar
C5 Cooling Fans Operation
The low speed cooling fan is commanded on when the coolant temperature reaches 108°C (226°F). It is turned off if the coolant temperature lowers to 104°C (219°F). The high speed cooling fan is commanded on when the coolant temperature reaches 113°C (235°F). It is turned off if the coolant temperature lowers to 108°C (226°F). When the A/C is on and the coolant temperature reaches 85°C (185°F), the low speed cooling fan will be turned on at vehicle speeds less than 56 kPh (35 mph).
Old 10-14-2009, 12:09 PM
99 vett babycar
99 vett babycar's Avatar
Also if your car has been tuned the on/off temps of each or both fans may have been changed by the tuner.
Old 10-16-2009, 02:30 PM
8th Gear
210007587's Avatar
Default Thanks
I appreciate all the responses. Great information.
Old 03-04-2010, 06:57 PM
PackedFunk
PackedFunk's Avatar
Interesting that 226 & 235 degrees F are the temps. for low & high fans to start. I just bought a '98 LS1 & seen 221 F with A/C off & thought I had a problem. I suppose this is normal & not to worry. Thanks for great info.
Old 01-01-2017, 04:36 PM
Artizan
Artizan's Avatar
With the AC on the fans (both) come on at low speed at 185 degrees. They both go to high speed at 194 degrees.
With NO AC running the fans come on at low speed when the coolant reaches 226 degrees. The both go to high speed at 235 degrees.
When the vehicle speed reaches 35mph the fans go OFF no matter what the coolant temp is. Air flow through the radiator is better with the fans freewheeling than with them running.
Hopefully ByronHunter will post the wiring diagram that can help you troubleshoot what may be happening. There are 3 relays involved in the fan operation. One or more may have failed or the fan that runs only on occassion may be worn out.
Thanks for posting that. I don't recall ever seeing the temp go beyond 220, even in the summer. Now, in the winter, I see the temp go almost 230, then the fan kicks in at idle. Always great to see that gauge trickling back down
Old 04-14-2019, 03:39 PM
NewportGeek
NewportGeek's Avatar
Is there an easy way to adjust the fan temps? Power Programmer device or phone app & OBDII ?
I installed a lower temperature thermostat and would like them to come on sooner.
Not looking for the expense of a full tune.
Old 04-19-2019, 03:57 PM
Zmeister
Zmeister's Avatar
Most of the hand held tuners allow you to set the temps when the fans kick on.
I know the Diablosports do, along with a lot of other handy things, including the ability to buy and load canned tunes from professional tuners.
Old 05-02-2020, 08:29 AM
royzee
Cruising
royzee's Avatar
Byron thanks for posting the wiring diagram c5 cooling fans - answered what I needed 2 know and THANK YOU!
Royzee
Old 05-02-2020, 07:59 PM
NewportGeek
just to close the thread I bought a Diablo Sport handheld tuner and was able to easily adjust the fan temps on both my C5 and my friends C6.
To Cooling Fans-when should they come on?
Quick Reply: Cooling Fans-when should they come on?
