P0418 and P0410
Cruising
P0418 and P0410
Yesterday I was poking around in the fuse box looking for a blown fuse after finding the correct fuse to changed (thanks to lucky at the corvette forum) I got everything working fine. the next time I drive the car I got a check engine light. I read the codes and had 1 code set, P0418, and 2 pending P0410 and P0418. Anybody have any experience with these codes? I can't help to think I loosened something, maybe a ground, while poking around in the fuse box. Any help would be appreciated. Thanks in advance.
Cruising
sorry about the broken link I'll do better next time. Fuse was good so I erased the codes but don't have a good feeling about their return. I'll find out tomorrow when I drive to work. Keeping my fingers crossed...
Cruising
It will throw the code regardless if it is an active problem or not. An "H" will come after the code if it has been corrected and is no longer an issue. The light will remain on until you clear the code(s) out.
Cruising
It's an active one. As a matter of fact I cleared it last night and it came back on this morning as soon as I got out of my drivway. ARGH!!
Anyone know the first thing about troubleshooting the AIR Pump Relay Control Circuit? If I had a schematic I know I could figure it out...
Cruising
p0410 and p0418
mil light is on code p0410 and p0418 the vacuum line that runs under the battery and into a black plastic box can you tell me what it is and can i bypass it and run vacuum straight to air by-pass valve for secondary air injection thanks
