Replacing coolant temp sensor??
Old 10-03-2009, 04:40 AM
gnguru
gnguru's Avatar
Default Replacing coolant temp sensor??
Can anyone tell me where it is on the engine and how to replace the coolant temperature sensor on a 2004 Z06?? Thanks,
Old 10-03-2009, 11:38 AM
lucky131969
lucky131969's Avatar
Forward left side of the drivers head, just behind the alternator. What problem are you having?
Old 10-03-2009, 12:29 PM
dgrant3830
dgrant3830's Avatar
Wounded Warrior Escort '11
FYI, the coolant temp sensor is critical to the engine operation via the PCM. As requested, if you are having problems, what problems and why this sensor? If it isn't working correctly, you'll probably have major mixture issues and worse. Codes?
Old 10-03-2009, 12:51 PM
fishdude7
fishdude7's Avatar
Right behind the alternator. Make sure the engines cool when you remove it or your feet are going to be soaked in scalding hot coolant.
Old 10-04-2009, 03:26 PM
gnguru
gnguru's Avatar
When I turn the ignition on all needles peg all the way over to the right as they always do including temp gauge and then back to the left. Then I start the car and the temp gauge starts at 0 and works it's way up to normal operating temperature around 180 or so and then all of a sudden the temp gauge will peg all the way to the right and stay there. When it does this the engine does not seem or smell hot or overheated whatsoever. Car runs as good as it always does. Thought the temp gauge would be the cheapest & quickest place to start with to solve this problem. Any thots? this reply to lucky131969 also for any ideas you may have. Thanx for any help.
Old 10-10-2012, 06:37 PM
John Ferrentino
1st Gear
John Ferrentino's Avatar
yes,I have the same problem with my 2001 corvette. I think its a bad coolant temp sensor.everything seams to be working fine.hav you got any answers?
Old 02-20-2013, 10:29 PM
Mojointn
Mojointn's Avatar
Default Same here!!!
I just installed long tube headers on my c5. It is very easy to break the coolant temperature sensor when installing the headers. Easy fix autozone had the part to replace it. As I started the car I noticed the car's temperature hand was pegged out within 10 seconds. Now I'm wondering if I possibly got a defective sensor or ???. Everything was fine before I damaged the sensor.
To Replacing coolant temp sensor??
Quick Reply: Replacing coolant temp sensor??
