Throttle body prices
Prices range from 100.00 to 350.00 for new ported 80 MM C5 throttle bodies. Does anyone know if there is a huge difference between the expensive ones and the poverty models. Thanks
If/when you get a new throttle body, do the re-learn right after it is installed or you will get crazy codes and a bad idle that at first will have you scratching your head.
