Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-10-2009, 09:00 PM   #1
tblt44
CF Senior Member
tblt44's Avatar
Default Intake manifold gasket replacement ??
I just found out my newly bought 1995 corvette has an oil leak from the front of the intake manifold.Is this a big job? I am pretty good at fixing things,starters,alternaters,clutch,ect,b ut never been inside a engine.
Should I do it my self or pay someone?
What would this cost?I got a quote from chevy of 464.00 is this high?
Thanks all I'm new to the corvette world
tblt44 is offline   Reply With Quote
Old 08-10-2009, 09:18 PM   #2
NeutronVette
CF Senior Member
NeutronVette's Avatar
Try posting your question here:
http://forums.corvetteforum.com/c4-tech-performance-48/
NeutronVette is offline   Reply With Quote
Old 08-10-2009, 09:31 PM   #3
01vetter
CF Senior Member
01vetter's Avatar
Ooops, see that you have a C4. What I say below for a C5 might still be valid.
The intake manifold has a gasket set for each runner. But, these can't be the problem because the intake manifold doesn't see any engine oil. The only possibe way for the intake manifold to be leaking oil would be if your PCV system is pumping oil into it and if one of your front runner gaskets isn't installed correctly. But, I doubt if this is your oil leak because you would see a vacuum leak and would be sucking the oil into the engine.
The other possibility, and most likely cause is your valley cover, which is under your intake manifold. The valley cover has a gasket on it that could have let go. Also, your knock sensors have rubber seals in their wells. One of mine let go and partially filled the well with oil. I suppose that it could fill all the way up and spill out onto the front of the engine.
Wher do you see oil leaking from??
01vetter is offline   Reply With Quote
Old 08-11-2009, 05:13 PM   #4
tblt44
CF Senior Member
tblt44's Avatar
Front right looks like at the intake.It's very hard to see.It,s around the distributor cap area or just above
Old 08-11-2009, 07:13 PM   #5
coxjajb
CF Member
tblt44, I have no specific experience with a 1995,, however, I once had an 84 and thought I had an oil leak from the back of the intake manifold. I replaced the gasket twice but it continued to leak. The leak turned out to be from the oil pressure sensor. It's located behind the manifold near the distributor. Again that was an 84. Just a though to check before you tear into your 95.
coxjajb is offline   Reply With Quote
Reload this Page Intake manifold gasket replacement ??
Tags
1984, 2002, 95, corvette, gasket, intake, job, leak, leaking, location, manifold, oil, replacement, runner, symptoms
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Leaky LT1 Intake Manifold Question Torre C4 Tech/Performance 31 11-02-2011 09:58 PM
'90 intake manifold gasket replacement caddydaddy C4 Tech/Performance 12 09-04-2005 01:24 PM
Anything else while intake Manifold gasket, Opti and waterpump being replaced? tobijohn C4 Tech/Performance 21 09-12-2003 12:53 PM
Intake Manifold Gasket kit for L98 BIG K C4 Tech/Performance 9 09-10-2003 06:13 PM
Head Gasket Replacement, Door Break-In Update B84RADR C4 Tech/Performance 16 11-19-2002 02:35 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
