Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-08-2009, 08:59 AM   #1
wreakhavoc
CF Senior Member
wreakhavoc's Avatar
Default Hard to shift into first gear
About 87,000 miles now. Sometimes it takes a lot of effort to get into first gear or it will seem like it's engaged but then will abruptly slam out of gear when I take off. No problems with the other gears.
wreakhavoc is offline   Reply With Quote
Old 08-08-2009, 09:17 AM   #2
k0ts
CF Senior Member
k0ts's Avatar
Send a message via AIM to k0ts Send a message via Yahoo to k0ts Send a message via Skype™ to k0ts
Same here... It's (I've) been doing it since I bought it and that was about 60k miles.. I suspect the "operator" is part of the problem... I've just over 80k on it now and it hasn't gotten worse or better... Nor has the operator... ;-)
k0ts is offline   Reply With Quote
Old 08-08-2009, 09:58 AM   #3
Mark C5
CF Senior Member
St. Jude Donor '08-'09-'10
Send a message via AIM to Mark C5
Fairly common C5 problem, especially the '97-'00 models that have the paper blocking rings. Try shifting into 2nd and then to 1st. The works 99% of the time for me. It's aggravating and eventually I'll replace the trans but you can live with it for a long time. Others will recommend changing the fluid, the Anti Venom mod or a different shifter and a shifter adjustment. Tried it all, same result.
Mark C5 is offline   Reply With Quote
Old 08-08-2009, 11:38 AM   #4
wreakhavoc
CF Senior Member
wreakhavoc's Avatar
It's not the operator in my case. I have had the car since it had 29,000 miles and it just recently started acting like this. What are paper blocking rings?
Old 08-08-2009, 01:15 PM   #5
Mark C5
CF Senior Member
Blocker rings are an intermediary part between the synchronizer sleeve and the gear cone. When the synchronizer sleeve slides over, it first pushes the blocker ring against the gear cone, and the blocker acts as a cone clutch to help speed up or slow down the gear to the desired speed prior to the synchronizer sleeve sliding over further to engage the gear.
The '97-'00 are paper and the '01 and up are compressed carbon.
Old 08-08-2009, 02:16 PM   #6
AJ Powers
CF Member
Send a message via ICQ to AJ Powers Send a message via AIM to AJ Powers Send a message via Yahoo to AJ Powers
Default Shifting
I changed to Royal Purple - noticed some difference.
I "Rangered" clutch fluid - noticed big difference.
AJ Powers is offline   Reply With Quote
Old 08-08-2009, 03:48 PM   #7
97C5owner
CF Senior Member
97C5owner's Avatar
Had the EXACT same problem with my 98 and posted many threads about it. Tried replacing shifter- no joy. Changing fluid- no joy. Everyone on The Forum kept telling me the 1st gear syncro was bad. Finally Broke down and did the rebuild at Corvettes of Houston.
Guess what. The 1st gear syncro was bad. When their mechanic showed me mine-vs the new one- I was amazed it stayed in gear at all. The small teeth become worn and rounded causing it to pop out of gear when engaged. A loud banging noise that really scares the hell out of you.
It is true about the paper blocking rings. But either way- rings or syncro- you're tearing into that trans and its pricey.
97C5owner is offline   Reply With Quote
Old 08-08-2009, 05:37 PM   #8
wreakhavoc
CF Senior Member
wreakhavoc's Avatar
Hard to believe it would go bad at less than 100,000 miles with normal driving.
Old 08-09-2009, 04:26 AM   #9
97C5owner
CF Senior Member
97C5owner's Avatar
Mine was ko'd at 53 k mi. But the schmuck who had the car before me couldn't drive to save his life.
Old 08-09-2009, 08:08 PM   #10
SPS
CF Senior Member
I had the same problem a number of years back. I was almost ready to have them open it up, but everything I read said "change the fluid". I changed the fluid to Mobil 1 and it made a world of difference.
Step 1 is change the fluid.
( I will probably see the next 10 posts telling me I should not have used Mobil 1 on a 98 with paper blocking rings, but I got a 100,000 miles on it now. The car has a few problems, but shifting isn't one of them)
SPS is offline   Reply With Quote
Old 08-10-2009, 02:35 PM   #11
2_99_c5s
CF Senior Member
I have the same problem in both my '99s. It's fairly common. Just make sure it's fully in gear before you move. If you have problems getting it into gear, just slowly let out the clutch while applying pressure to the shifter. Have faith, it'll pop right into first.
2_99_c5s is offline   Reply With Quote
Old 08-11-2009, 12:15 AM   #12
jedblanks
CF Senior Member
jedblanks's Avatar
Good to hear you got this resolved.
For the OP, I would just try sliding it into 2nd or 3rd before first, sometimes it will help. You almost certainly have some wear and it just depends on how long you can live with it.
jedblanks is offline   Reply With Quote
Old 08-12-2009, 09:07 AM   #13
jraddington
Junior Member
jraddington's Avatar
Default Shifter
I have had a similar problem with my 99 6-Speed. I too found that going back to 2nd before sliding into 1st makes it work perfectly most of the time.
If you move the shifter into 1st very slowly you can feel it hit two distinct "notches". Sometimes the first notch can feel like it is all the way in, and letting out on the clutch will either pop it out of gear or grind like crazy.
I remedy this on my car, I did the following:
1 - Shifter alignment ( pretty quick and free, helped a little )
2 - Lubed the shaft ( quit laughing, I put lube on the shifter linkage at and around the shifter. Best to do with shifter alignment. Cheap and made the shifter buttery smooth. )
3 - Changed to Royal Purple fuild. This did make another small difference I could feel.
After all of these steps I have not popped out or grinded gears once... But my wife still does it once or twice when she drives. She just doesn't push hard enough on it.
- Josh
jraddington is offline   Reply With Quote
Old 08-12-2009, 09:49 AM   #14
wcsinx
CF Senior Member
wcsinx's Avatar
Mine can be bear going into 1st from a stop as well. It got quite a bit better when I put in fresh tranny fluid. And I even went cheap with plain old dino Castrol Multivehicle ATF.
Also I think on a lot of our cars the clutch still drags ever so slightly with the pedal all the way down loading the transmission a tad. Keeping the fluid clean helps. Getting a higher volume clutch MC (like the Tick) probably would help more. What leads me to believe this is with the engine off, my car will slide into first like butter. Whereas if it's idling, there's that little "hump" getting it in. Additionally if I come to a stop without engaging the clutch in neutral then it also slides right into first with no effort at all. But if I come to stop, shift neutral, engage clutch (pedal out), wait, disengage clutch (pedal in), then try for first ... there's that "hump" again.
At some point I'll get the Tick adjustable MC.
wcsinx is offline   Reply With Quote
Old 08-13-2009, 06:00 AM   #15
ghutch
Junior Member
ghutch's Avatar
My 97 has 48K miles on it. It has been popping out of gear since it passed 30K miles. I found that if I down shift into first before each stop I can get it to align properly and that has resolved the problem for now. My friends 05 has less than 20K on it and he has complained about it popping out of gear too.
ghutch is offline   Reply With Quote
Reload this Page Hard to shift into first gear
Tags
1st, 2005, align, bad, c5, c6, corvette, fl, gear, hard, mechanic, melbourne, popping, shift, shifter, shifts, synchronizers
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Startegies used to get into 2nd while autocrossing?? TedDBere Autocrossing & Roadracing 15 09-20-2003 05:08 PM
Hard to go into first and second gear sometimes, is this normal? BrightRed C5 SWFL C5 Tech 9 01-12-2003 10:25 PM
Will try to get into 11's this Saturday!! (Bradenton - Desoto Speedway) GrandSportC3 C3 Tech/Performance 46 10-30-2002 07:54 PM
Why is my tranny so hard to shift in the morning? NE14SIN C4 Tech/Performance 11 08-17-2002 07:54 PM
Very hard to shift into reverse. Help! ruskus C3 Tech/Performance 11 06-12-2002 11:11 AM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
