Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-05-2009, 01:24 AM   #1
lawin45
Junior Member
Default z06 stalling
can anybody help me with this... everytime i start running on 1st gear and about to come on a stop, push the clutch in, the engine dies. same thing with reverse. Does anybody had this kind of problem???? pls help...
lawin45 is offline   Reply With Quote
Old 08-05-2009, 01:28 AM   #2
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Support Corvetteforum!
Bill Curlee's Avatar
AAAAAAAAAAAAAAAAAAA,,,,,,year,,,,,Mods,, ,,,mileage,,,,,,,,,,,,,other critical information like DTCs????
BC
Bill Curlee is offline   Reply With Quote
Old 08-05-2009, 01:50 AM   #3
lawin45
Junior Member
2003 z06, 43000 miles, before starting the engine, message reads, "service steering column".
Old 08-05-2009, 04:59 PM   #4
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Please read and POST your DTCs IF,,,,,,,,,you have numerous DTC,,,clear them all and see what ones come back. Heres the procedure:
READING YOUR Engine Diagnostic Codes
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold OPTIONS
4) While holding OPTIONS, press FUEL four times within a 10-second period.
Initially, on-board diagnostics go into an Automatic Mode which shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two kinds of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current C code indicates a malfunction is present and active in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes.
More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except English/Metric (E/M). Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press and hold the RESET button To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5. You can GOOGLE the DTC and also find information on it.
Here is very good site that explains the DTCs:
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix!!
Reload this Page z06 stalling
Tags
2001, c5, c6, clearing, cloumn, codes, column, corvette, diagnostic, light, mode, service, sreering, stalling, z06, zo6
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
FS: 2003 Torch Red LGM Z06 550HP!!! Only 1600 miles!! Mint!! $42995!! TorchRedZ06 C5 Corvettes for Sale 75 02-29-2004 10:38 AM
MAX RWHP WITH CAM ONLY Z06! vettethret C5 Tech 24 12-18-2003 06:12 PM
New Dyno results Z06 with only mods= G5X-1 cam and LG Pro Long tubes, 2 zip ties LG Motorsports C5 Tech 28 12-08-2003 11:45 AM
Z06 Brakes are Dangerous 1FunZ06 C5 Z06 Discussion 10 05-24-2003 10:16 PM
Z06 performance compared to New Viper C4ForGeeGee C5 Z06 Discussion 116 12-09-2002 04:10 PM
Blackwing on a 99 FRC can i cut the shroud?? Mike TexaSS C5 Tech 16 06-09-2002 03:42 PM
Damn it, so confusing!! Z06 airbox/K&N or the Blackwing!!! Venger C5 Tech 66 04-25-2002 04:38 PM
My Z06 is runing strange please help.? NVMYC5 C5 Tech 17 03-13-2002 02:56 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
