PCM P0410 Secondary Air Injection System Malfunction
Cruise-In VIII Veteran
St. Jude Donor '07
Well, my car is ticked. It throws this code almost daily and I had the air system tuned out of my last C5 so it is getting irritiating. I know that there is no real way around this, so my question is...
Does running/driving the car with this code/issue lead me into any other issues/concerns I need to worry about?
Will it hurt the car?
Information on this would be most useful.
Thanks,
Micah
Thanks,
Micah
Micah - I doubt it will hurt as the code is an indicator it failed the AIR test cycle on both sides during normal closed-loop operation. As you know, the AIR system is active during the first couple of minutes during cold starts to reduce emissions and is also tested periodically by the PCM as a normal part of engine operation.
I can send you the diagnostic if you email me your regular email address.
I too am getting codes so is there anyone in Minnesota who would "tune" out the AIR system for me?? Or can someone tell me which program tuners (DiabloSports, HP tuners, etc) will do the job??
thanks
joe
thanks
joe
Hi...first time poster here. I don't have the code number, but my mechanic said it was a secondary air injection system malfunction. I've got the 2001 base coupe, not the Z06. I've been told the likely cause is moisture accumulates in the air pump and eventually corrodes or freezes and damages the pump, but it is a California emmissions thing and is only active for the first couple minutes after start-up. But do I want to have the engine warning light on all the time? I understand the replacement kit is around $500 plus installation. Is there any way to "tune it out"?
SpeedRacerMach (03-29-2019)
