needle on gauge cluster removal
Old 08-05-2009, 01:09 PM
mvvette97
mvvette97's Avatar
St. Jude Donor '06-'07-'08-'09
I was doing some searching and I read that there is a small electrical board that I can just change from one cluster to the other so I can keep the correct milage.
Old 08-05-2009, 01:43 PM
LoneStarFRC
LoneStarFRC's Avatar
Location: Dear Karma, I have a list of people you missed.
I have seen that info too.
Old 08-05-2009, 03:02 PM
mvvette97
mvvette97's Avatar
Anybody know are the clusters the same for all the years C5?
Old 08-05-2009, 06:12 PM
LoneStarFRC
Functionally they are. The only differences I'm aware of are:
1. The early IPCs ('97 to mid - late '99) were non HUD capable. After that time all IPCs had HUD capable circuitry in them regardless of whether or not the car it was installed in had RPO code UV6 installed at the factory.
2. Beginning in '01, a Z06-specific graphic design on the face (letters "Z06" on the face, checkerboard background pattern and higher redline) was introduced, in addition to the standard design as in previous years for all non-Z06s. Functionally they were the same.
The later "HUD ready" IPCs will work in the earlier cars.
Old 08-05-2009, 07:34 PM
dgrant3830
dgrant3830's Avatar
Wounded Warrior Escort '11
My '99 had a HUD and I bought it new. The extra IP Cluster that I have is out of a '99 also and has the hud connector on it.
Old 08-05-2009, 08:15 PM
mvvette97
mvvette97's Avatar
ok thank. anybody have one for sale? just the regular one is all i need
Old 08-05-2009, 11:59 PM
mvvette97
mvvette97's Avatar
Well i have one more question. I was looking at some clusters on ebay and noticed that alot of them have buttons on the left side that say display, page and have a slider. Mine does not have that so will these not work on mine?
Old 08-06-2009, 01:11 AM
dgrant3830
dgrant3830's Avatar
Those are the hud controls. I truly haven't seen what the cluster looks like in the cases where there is no hud. What's in the place?
Old 08-06-2009, 01:16 AM
mvvette97
mvvette97's Avatar
There is just a black plastic fill panel in the place of the buttons. I wonder if those will work on the non HUD?
Old 08-06-2009, 04:29 AM
tstar
tstar's Avatar
St. Jude Donor '11-'12-'13-'14-'15
I don't see why the HUD switch wouldn't work for you. It would PROBABLY just ignore the the HUD controls becuase it's not programmed to recognize them.
Also on the mileage swap, there were a few discussions on it and I believe the outcome was that you have have to swap the main motherboard to transfer your milage to the new IPC...
Tim
Quick Reply: needle on gauge cluster removal
