Intermittent Fuel Gauge Problem
I've been following the threads concerning the intermittent fuel gauge problems ever since I found the "Bill Curlee" post regarding grounding issues. I have a 97, and I too have the problem with the gas gauge showing the fuel level at start up, then immediately going to empty, the check gauge light comes on and DIC shows low fuel. I added Techron last week, cleared all the codes last night but the darn gauge will only operate for a few seconds before heading to empty. From the posts I've read, I'm to add Techron several times more with the hope that it starts working again. If this fails do I assume its the sensor or a bad gauge? Is there a way to troubleshoot these? Thanks for the assistance. Please excuse me if I failed to see this from the numerous threads regarding this problem.
St. Jude Donor '09-'10-'11
Hope the Techron does the trick for you!
In combination with the fuel system cleaner chagne to a better brand of gasoline www.toptiergasoline .com
IF that does not fix it check for corroded grounds.
IF it still isn't properly working, it is time for new fuel sending units.
Search in the archives for a post on replacing them without dropping the gas tank.
Do try the Techron a few more times before replacing anything. It took three treatments before mine started to work again and works fine ever since, well over a year now. If it doesn't work for you chances are the sending unit will need to be replaced. There are two. If the gauge cycles on startup (goes from E to F) then it is working. The sending units get a deposit build-up on the resister that some have pulled out of the tank, cleaned, and reinstalled. Some other folks just replace them.
As luck would have it, I drove the car yesterday running errands and suddenly the gauge started working again. I've decided I'll start burning Shell gas and see how that goes. I appreciate everyones inputs. This is a great place to get helpful info and advise.
Btw, bear in mind that there are a variety of gasoline blends being sold throughout the country. So, depending on the state you live in, the time of year (the additive packages are seasonal on some states), and whether it's a top tier, etc, etc, all these could be factors too.
