c6 Z06 brakes conversions for the c5's
Old 07-21-2009, 06:02 PM
SICK-VETTE
Support Corvetteforum!
SICK-VETTE's Avatar
Default c6 Z06 brakes conversions for the c5's
Can anyone tell me what i need to do this conversions?
Thank you
Joe
Old 07-21-2009, 07:00 PM
IMD
IMD's Avatar
a set of calipers, a set of pads and a set of rotors.
Old 07-21-2009, 07:09 PM
SICK-VETTE
SICK-VETTE's Avatar
do i need stainless steel lines?????
Old 07-21-2009, 07:25 PM
daveydc5
daveydc5's Avatar
You need to be thinking about wheel fitment issues as well. Unless you really want calipers that say Corvette, you should also be looking at some of the other options such as Brembo, Wilwood, etc.
You should call a couple of supporting vendors such as LG, that can tell you what the options are and which wheels fit. From a performance POV, you can do better than the ZO6 option for similar money. But the ZO6 calipers look pretty sweet!
You don't need SS lines, but they are nice and will improve pedal feel. OEM ZO6 lines should work just fine for street application.
Old 07-21-2009, 07:32 PM
IMD
IMD's Avatar
where can you find a better 6 piston caliper for under $500 a piece?
Old 07-21-2009, 07:37 PM
SICK-VETTE
SICK-VETTE's Avatar
I have wheels that fit.. so your telling me i dont need ss lines?
Old 07-21-2009, 07:38 PM
SICK-VETTE
SICK-VETTE's Avatar
I got the set for under $800 CDN but no SS lines
Old 07-21-2009, 07:44 PM
IMD
IMD's Avatar
exactly. the other guy was saying that you could get a better caliper for the same money... and i dont think so.
you dont need lines, they just improve the feel. if you're in there already, might as well throw them on. otherwise, you're good to go. just bolt the stuff on and go. justr like you're doing a routine brake service.
Old 07-21-2009, 07:48 PM
SICK-VETTE
SICK-VETTE's Avatar
Thank you buddy when i get them done i will post pic's for you guys!
Old 07-21-2009, 08:09 PM
Its_Go_Time
Its_Go_Time's Avatar
I had to angle my rear hoses up on a 30 degree angle at the caliper. Otherwise, no problems exept wheel fitment. What kind of wheels did u pick? R U sure they fit?
Old 07-21-2009, 08:16 PM
Trpblk04
Trpblk04's Avatar
I have a question, why do people install this system at over $2k?
1. It looks cool?
2. You auto x and need the extra breaking power?
3. Because you can?
4. You drag race?
I think it is a waste of money.
Old 07-21-2009, 08:22 PM
SICK-VETTE
SICK-VETTE's Avatar
iForged Aero but im only doing the fronts
Old 07-22-2009, 07:29 PM
cdn ws6
cdn ws6's Avatar
When I did this conversion in April of this year, I ordered up a set of braided brake lines from Randy at Doug Rippie Motorsports. They are made by Goodridge but don't have the block type fittings, instead, they just screw into the caliper. Aside from the brake lines the only things I needed were some brake fluid and thread locker.
BTW, this conversion can be done, front and rear, for approx $1100-1300 if you buy the calipers/pads/rotors used and there is a noticeable performance difference, at least on the street!
Give me a shout if you have any questions!
Good luck with the swap and post up some pics!
Old 07-22-2009, 07:41 PM
daveydc5
daveydc5's Avatar
Yeah, your right. You're definitely into more money for a different system. The C6 ZO6 is good value. If you have wheels that fit, and the money is an issue, the C6 is a decent choice. You DO NOT need SS lines, but I would do them any way.
I'd personally pony up for a higher hend 6 pot system that uses a large single pad like Brembo or Stoptech. But definitely more money as I was corrected below.
Old 07-22-2009, 08:51 PM
Eric Reeves
Eric Reeves's Avatar
The calipers themselves are as good as anyone else's 6 piston setup. Prove where it isn't. As for the padlets, there are single pad options out there for this exact setup that are way superior to the padlets. Therefore, if you have equal calipers and single pads how are you going to top it? We a are now into the tires and suspension setup because the brakes are doing all they can. Plus with the C6Z setup, you get all four corners compared to just the fronts on other systems for still less money.
Old 07-22-2009, 10:17 PM
Humy
Humy's Avatar
What are the wheel specs to make sure they will fit? will 18/19 C6 Z06 factory reproduction wheels have the clearance?
Old 07-23-2009, 12:21 AM
cdn ws6
cdn ws6's Avatar
kore3 dot com has templates to verify wheel fitment
To c6 Z06 brakes conversions for the c5's
Old 07-24-2009, 12:41 AM
KRISCO
KRISCO's Avatar
1. It looks cool?
3. Because you can?
4. You drag race?
So. Why would you bother posting this crap?
Old 07-24-2009, 12:53 AM
QKSLVR Z
QKSLVR Z's Avatar
try to get these lines from VBP instead:
http://www.vbandp.com/SearchResult.aspx?CategoryID=417
you can angle them however you want..
Old 07-24-2009, 12:48 PM
Mankra
Mankra's Avatar
Originally Posted by cdn ws6
Sorry for Offtopic:
Which Rims are this?
Can you tell me the dimension of the rims and brand?
The Z06 Brakes fit under it, without wheelspacers?
Quick Reply: c6 Z06 brakes conversions for the c5's
