Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-23-2009, 09:32 AM   #1
Superman09
Supporting Vendor
Superman09's Avatar
Send a message via AIM to Superman09
Default Lightweight clutch/flywheel VS Standard weight
I'm curious about all the effects of switching to a lightweight chromoly or the like flywheel/lightweight clutch assembly. I drive my car on the street everyday so it rarely see's dig launches on the street, just rolls. I do however enjoy going to the 1/4 mile track once a month or so for fun. I've heard that the light set-ups will help the car rev therefore being fun from the roll blasts, but will bog me down on launches at the track. What do you guys suggest? If you suggest light, whats the limit as to how light? I like that RPS Organic twin disc with the lightweight flywheel but it might be too light? Please educate me
Superman09 is offline   Reply With Quote
Old 07-23-2009, 11:50 AM   #2
mcgilles
CF Senior Member
mcgilles's Avatar
sorry I can't offer anything more than popcorn...but I'm interested in your question as well.
mcgilles is offline   Reply With Quote
Old 07-23-2009, 02:11 PM   #3
dmiz0420
CF Senior Member
dmiz0420's Avatar
Twin disc pressure plates can be heavy and end up weighing about the same as stock depending on the flywheel.
Unless you’re going with a quartermaster clutch with 5" discs you can use a light weight flywheel and pressure plate without a problem.
RPS twins weigh about 42lbs, stock ls1 ~ 50lbs, ls7 ~ 60, spec stage 3 light weight pressure plate and aluminum flywheel ~ 35lbs...
Bogging is all going to depend on your release and engine power. If you can compensate for the lighter weight as the clutch engages there shouldn't be an issue. Lets face it, we compensate for clutch engagement weather we have a light weight clutch or not.
dmiz0420 is offline   Reply With Quote
Old 07-23-2009, 02:12 PM   #4
Ikester
CF Senior Member
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Ikester's Avatar
Send a message via AIM to Ikester
Quote:
Same here, from my past understanding was that lighter flywheels are great for performance (less rotating mass) however the drawback is a noisy tranny when your sitting there at idle. Now this was with an aluminum flywheel. the chromoly is a different material im guessing so I cant speak for it.
some people dont care about the extra noise, for me i like my vette quiet except for the exhaust sound
Ikester is offline   Reply With Quote
Old 07-23-2009, 02:34 PM   #5
dmiz0420
CF Senior Member
dmiz0420's Avatar
Do you know the aluminum makes more noise from experience?
If you had a bad throw out bearing yes other wise I can't see how aluminum would cause more noise at idle or any other speed. I'm guessing sitting at idle with the trans in neutral.
Aluminum flywheels have sintered steel inserts for the clutch plate to bare on.
Maybe the intermediate plate on SOME twin discs rattle when you press in the clutch and it unloads.
I havn't noticed any extra noise but can't tell because I have lg pro headers off road x pipe and cat back...
Old 07-23-2009, 03:05 PM   #6
AU N EGL
CF Senior Member
AU N EGL's Avatar
almost all aftermarket clutches make noise.
AU N EGL is offline   Reply With Quote
Old 07-23-2009, 04:01 PM   #7
intoc6s
CF Senior Member
intoc6s's Avatar
Spec 3+ and Aluminum Flywheel- I don t hear anything but headers/exhaust. But i will say FROM EXPERIENCE, The engine will rev up more quickly and as for drag racing- I was scared of "less inertia" out of the hole, but with my current engine with a 4" stroke(427) it takes off great! With stock cubes I couldn t tell u. Maybe someone will chime in and say...
intoc6s is offline   Reply With Quote
Reload this Page Lightweight clutch/flywheel VS Standard weight
Tags
aluminum, c5, clutch, corvette, effects, flywheel, light, lightened, lightweight, ls1, noise, noisy, rps, standard, weight
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Corvette Parts News! New C6 Section! 8/28/04 CorvettePartsBob Ken's Newsletters 9 10-05-2004 11:23 AM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
