Broken Seat plastic part
The plastic side piece that holds the electronic control *** broke on me, and I have a couple questions I hope someone knows the answer to.
Here is what broke on a 98 coupe, standard electrical seats.
First off, what is this part called, so I can order a new one?
Im not much of a wrench. How do I remove the seat back lever so I can put a new one on?
And third, It probably broke because the seat is pretty worn down. Can I switch the passenger and driver seats fairly easily? They are both electric.
Thanks!!!
Thanks!!!
I just purchased the same piece because I'm having my seats redone. Mine broke on the sides and it's caused by the foam being too worn. I paid $32 plus tax (total for both pieces) locally from Corvettes of Houston.
GM part# 1245-5427 Passenger side
GM part# 1245-5426 Drivers side
Location: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
I have a new spare if you want it assuming you need the passenger side. paypal me $25 and I'll mail it to you.
jgira12@yahoo.com is pp address
Premium Supporting Vendor
They aren't that expensive new. Please check out my website or contact me directly and I'll be happy to help you.
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Phone: 484-334-8833
Mine broke the same way within a week of installing new seat leather and foam
I have a replacement piece waiting to go in - it's been about 4 years since the install, but I always thought it was about the hole in the foam not being right
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I glued mine and it worked fine. You cant even really see the repair.
BC
BC
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Just re-glue it and once its dry/cured,,,redrill the hole in the frame so that the plastic bracket fits nicely on the seat. The drill bit that you need is small and the screw is a self tapping screw.
BC
BC
I hear ya...i lost the screw years ago, but I have tons of self tappers in the toolbox...I might even try a plastic xmas tree type.
Well I finally got around to installing the new part today. Went fine until I tried to put the front screw in. Cant for the life of me get it in the hole! Guess the seat is so far out of shape it doesnt line up very well.
So I need a small bit, to drill into the frame which is metal? and a self tapping screw... any suggestions on size?
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You aint drilled that new hole yet Get her done!
BC
BC
