"Shifter Adjustment" Question
#62
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
#64
Bringing up a dead thread. Here is my issue.
1st - Sometimes it is hard to put it in first from a stop.
- simply putting it in another gear it goes right in but does not happen often
2nd- Does not want to go all the way in. Has popped out. I tend to skip 2nd(this is not all the time about 20 percent the time there is an issue)
- Slight grind for quick shifting.
3rd - Has started to grind on quick shifts(did not happen before clutch and slave change)
4th- slight grind going in for quick shifts(same as third)
5th- fine
6th- fine
Reverse- Have not any issues.
I will be doing the shifter adjustment as soon as I can and will post an update.
-1998 C5 6spd manual with 80.5k miles
- aftermarket short throw shifter...Possibly a B&M shifter.
- Monster stage III clutch with new stock slave cylinder(old was leaking)
After the adjustment, I will drive for a week and then change the fluid.
5th- fine
6th- fine
#65
I realize this is a "trial and error process", but I would just like some guidance to steer me in the right direction. I don't want to have to tear down the center console a dozen times before I get it right. I don't have any problems with the car popping out of gear...just tough to engage 1st and reverse from a dead stop on occasion.
Unless you are a skilled mechanic, which I'm not, sometimes better to bite the bullet and take it to the pros. Corrollary, sometimes the simplest fix (basic maintenance) does the trick.
#66
Hey guys, I'm doing a shift alignment on my c5 z06 with a B&M short throw. Do I still need to find a pin to stick in the alignment pin hole? Or can I do the adjustment without the alignment pin? First time doing this so I want to be cautious.
#67
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I have done numerous shifter alignments. NO you do not need the pin to do it if you fully understand what the alignment does and why its important.
Its your first time doing the shifter alignment. Use the pin and see what its all about.
BC
#68
Just use a DRILL BIT that fits SNUG in the hole!! You do NOT have to have that damn L shapped OEM pin.
BC
BC
#69
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Is the shift shaft BINDING inside the bushings in the box??? You can add a little synthetic grease to the shaft and bushing and see if that helps.
The lower Box has bushings that can and do wear out. Chech for binding and or excessive play when you mobe the shaft bu hand and also try to move the shift handle in all directions.
BC
BC
