Rebuild Power Seat Switch?
Old 05-13-2009, 05:31 PM
thetitan
thetitan's Avatar
Default Rebuild Power Seat Switch?
I beleive that the passanger side power seat switch is not working on my 1998 Vette with sport seats.
Does anyone know if it possible to rebuild, and/or clean the contacts in the switch unit?
Old 05-13-2009, 06:16 PM
byronhunter
byronhunter's Avatar
No switch functions work? Some switches work , some don't? Power to the seat? More information would help!!!!!
Old 05-13-2009, 10:33 PM
thetitan
thetitan's Avatar
Thanks for the interest and help. The specific problem that I am having is that the switch that makes the seat go forward and up, works only sometimes if you jiggle it back and forth, I think that the contacts in the switch are bad. I put direct power to the motors and all of the motors worked perfect.
Old 05-13-2009, 10:59 PM
byronhunter
OK, I posted the wrong info for this thread.
If it were me I would try taking it apart and cleaning the contacts. I just cleaned the contacts in a multifunction switch, i can't imagine it being more involved than it. Let us know how it works out.
Old 05-14-2009, 07:26 AM
thetitan
thetitan's Avatar
Is the switch housing screwed together or does have to be cut open?
Old 05-14-2009, 11:12 AM
byronhunter
Not sure, even though I've had one in my hand 2 different times. Just didn't pay enough attention to it. I would guess it is not glued together. Probably clips or screws, or maybe both. Sorry! Someone will probably jump in and let you know.
Old 05-14-2009, 11:53 AM
LoneStarFRC
LoneStarFRC's Avatar
Location: Dear Karma, I have a list of people you missed.
Worth a shot I guess. New switch:
12135159 $148.85
12135158 $107.69 with lumbar
That's forum price, not list price.
Old 05-14-2009, 02:33 PM
Slick Rick
Slick Rick's Avatar
I had to replace switch on my passenger seat. You cant repair them, case is molded you have to gut it open to get to the guts. Pretty simple job. Call Gene he has the best deals on switches.
Old 05-16-2009, 09:17 PM
REDZED2
REDZED2's Avatar
Don't mean to hijack. I have a dead power driver seat on my Z06. Its either the switch or the whole adjuster(motor assembly.) How does one connect direct power to the seat motors to see if they work? I need to know if I need to order a whole new adjuster assembly $$$$ ( expensive) or just a new switch $.( cheap)
Old 05-17-2009, 12:26 AM
LoneStarFRC
First, remove the seat. Yeah, yeah I know ...but it's still the best way to access the motor(s). Each motor has a pair of leads coming out of it and they go to a connector. Unplug the connector for the particular motor you want to check and put your power/ground on the two leads. BTW, reversing the leads reverses the direction of the motor.
HTH
Old 05-17-2009, 11:11 AM
byronhunter
Check this thread, schematics.
http://forums.corvetteforum.com/c5-t...t-working.html
Old 03-05-2017, 09:51 AM
James2000
James2000's Avatar
Default Passenger sport seat
Where can a get a switch at this price? Thanks!
12135159 $148.85
Old 11-08-2017, 01:42 AM
Dwelty1
4th Gear
Dwelty1's Avatar
Default C5 seat control switch
12135159 $148.85
Do you still sell switches for this price?
Old 11-08-2017, 07:32 AM
SG Lou
SG Lou's Avatar
Considering those prices were quoted 8 yrs ago.....i doubt it
Old 11-08-2017, 07:53 AM
runner140*
Support Corvetteforum!
runner140*'s Avatar
12135159 $148.85
OR, buy a set of used sport seats that have full working electronics. I've got a set for sale here.
Old 11-08-2017, 12:44 PM
Dwelty1
4th Gear
Dwelty1's Avatar
Default Really??
Do you really spend your time needlessly checking and criticizing other peoples posts? I am well aware of the dates on the thread!
Old 11-08-2017, 03:45 PM
911AXER
911AXER's Avatar
Default 1998 power seat switch
Originally Posted by 8VETTE7
Yet another NEWBIE with an attitude problem!!!!!!!!!!!!!!
Good luck finding a cheap seat switch.
On a happier note call Vettetronics at 719-548-1023; they repair/refurbish them. Or you can find Vettetronics on Ebay.
Last I checked $99.00 send in your old one and they'll fix it for you.
To Rebuild Power Seat Switch?
Old 11-10-2017, 04:59 PM
SG Lou
SG Lou's Avatar
First thing I said to myself when i read his post
Old 11-10-2017, 05:14 PM
jakazz425
jakazz425's Avatar
If anyone is interested in this, the repair is very simple with a little bit of time and basic soldering equipment. Most of the time with the boards corrosion makes it through the trace protection (green stuff coating all the traces on the board) and disrupts the trace. I fixed mine by scratching the protectant off right in front and behind where the corrosion or broken point is, all the while being careful not to break the trace, then using a voltmeter check the continuity from the point you scratched off to the corresponding pin on the board, and solder joint. If its good, solder a small guage wire to bypass the corroded spot, then check for continuity again. My description may be really bad, I'll post pictures of mine when I get home for anyone interested.
SG Lou (11-10-2017)
Old 09-04-2018, 10:32 AM
VettetronicsInc.
1st Gear
VettetronicsInc.'s Avatar
Default Wrong contact information for switch repair
I am the owner of Vettetronics Inc. in Colorado at the above listed phone number. We do not repair C4, C5, C6, ect electronic components. Never Have. Been in Business since 1985. I believe there is some one with a similar EBay screen name that is doing these repairs. My company has no affiliation with those people.
Quick Reply: Rebuild Power Seat Switch?
