Can I run 275/45R18 all around?
Re: Can I run 275/45R18 all around? (SILVER 97)
Yes, I just got done reading an article in the new issue of Vette and they tried several different wheel and tire sizes. You can do it with no problem :cheers:
Jerry
Jerry
Re: Can I run 275/45R18 all around? (99 Corvette)
Cool, thanks for the info,
I thought that there might be a rubbing issue. Also I thought I heard of problems with the ABS/Traction control system.
Hopefully not.
Hopefully not.
Cruising
See this recent thread:
http://forums.corvetteforum.com/zerothread?id=230442
There you'll find some advise to maintain the front/rear tire size difference. I would think the taller 18" wheels with 45 tires could present a rubbing issue on front but I don't really know. Have you considered the change to your speedo (slower with larger diameter tires)?
I have read similar posts, and there is always a warning about the taller tire up front causing havoc with active handling.
On my street car I run 285's front with 295 rear. The only issue I have had is when the car was lowered too much the top of the tires would rub the inner fender. I rasied it back up a 1/2" and it now clears. Wheels are stock y2k 18" all around. I do run a fair amount of neg camber. 1-2 degrees.
