17"x11" C4 ZR1 wheels touching C5 upper rear ball joint???
Trying to mount our 335/35-17 Hoosier Drag Radials. They're mounted on C4 17"x11" ZR1 wheels with 50 offset. Everything fits with the exception of the inside of the wheel barely touching the upper ball joint. I know a few others have ran this combination, so how did you get around this? Is it feasible to remove a little metal from the top of the ball joint?
Frank
Frank
A spacer will space the wheel out. I'm having contact with the inside diameter of the wheel touching the ball joint. I have clearance for the wheel and tire everywhere else.
Frank
Frank
