Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-03-2009, 09:17 PM   #1
wjsullivan
CF Senior Member
Default Glove Box Handle Broken - Won't Open - HELP!
Went to open the glove box (the one in the passenger side dash) and the handle breaks free in my hand. But the glove box doesn't open. I've spent an hour messing with it. By my estimation, without the handle the latch shouldn't hold the door close. It should just fall open.
I can't seem to get the latch to release. Any ideas? The latch/handle mechanism basically broke in two. The handle just came off with the lock still intact.
wjsullivan is offline   Reply With Quote
Old 05-04-2009, 09:08 AM   #2
wjsullivan
CF Senior Member
bump... I can't be the only one to have this issue.
Old 05-05-2009, 08:43 AM   #3
wjsullivan
CF Senior Member
bump... Really nobody has had this problem?
Old 05-05-2009, 06:26 PM   #4
wjsullivan
CF Senior Member
PM Bump... Come on somebody has seen this.
Old 05-06-2009, 08:41 AM   #5
wjsullivan
CF Senior Member
This is just getting depressing... come on.
Old 05-06-2009, 09:13 AM   #6
vette29209
CF Senior Member
vette29209's Avatar
Send a message via Yahoo to vette29209
mine broke to ! but the whole thing came out. i put it back in for the meantime. the only thing that is holding it up is the lock. i put the key in and turn it to hold it in place. might want to start there. the key might release it for you. good luck
vette29209 is offline   Reply With Quote
Old 05-06-2009, 05:26 PM   #7
TEXHAWK0
CF Senior Member
TEXHAWK0's Avatar
You 2 must be the only ones that have ever broke the glove box.
TEXHAWK0 is offline   Reply With Quote
Old 05-07-2009, 08:30 AM   #8
wjsullivan
CF Senior Member
Quote:
Guess so.
Old 07-01-2009, 11:27 PM   #9
myrcastle
Junior Member
In case anyone is listening, it is July 1 2009 and my 2006 glove box door handle just broke into pieces. Now it won't open. Any ideas on how to open without damaging the door itself? There doesn't seem to be much out there on this failure - help!
myrcastle is offline   Reply With Quote
Old 07-01-2009, 11:39 PM   #10
lucky131969
lucky131969's Avatar
Send a message via Yahoo to lucky131969
Quote:
Hmmm, you have a 2006.....still under warranty?
lucky131969 is offline   Reply With Quote
Old 07-02-2009, 09:53 AM   #11
wjsullivan
CF Senior Member
OK, yes the door should just fall open. The back of the v arm that the lock bar sits in when the glove box is closed has a notch that the arm on the handle holds in place. If the handle falls out and the arm comes with it the glove box should just fall open.
To get mine open I had to take a dremel and cut away the rest of the latch until the screws gave way. Then put a new latch back in.
Old 09-19-2009, 08:51 AM   #12
Edhar
Junior Member
Default Glove Box latch
I live in Oklahoma City and my dealer tells me there is not a latch, for my broken glove box, available . Does anybody know where I can get one?
Edhar is offline   Reply With Quote
Old 09-25-2009, 08:48 PM   #13
myk7
CF Senior Member
myk7's Avatar
Send a message via ICQ to myk7
http://willcoxcorvette.com/advanced_...keywords=glove
myk7 is offline   Reply With Quote
Old 02-18-2010, 03:09 PM   #14
DPeter2101
Junior Member
Default Broken Glove Box Latch
I have a 2007 and mine just broke. As I went to open the glove box the latch snapped in two. I did not even pull hard on the thing. I used pliers to pull down on the little metal tab. and it opened. But this still sucks as I'm out of warranty.
DPeter2101 is offline   Reply With Quote
Old 09-29-2010, 01:55 PM   #15
Splasha1
Junior Member
Splasha1's Avatar
Quote:
Probably made in China. Mine just broke also 2007. $62 bucks at Ecklers; afraid to see how much the stealer wants. Of course warranty just ran out.
Splasha1 is offline   Reply With Quote
Old 09-29-2010, 02:09 PM   #16
00Corvette
CF Senior Member
00Corvette's Avatar
Did either of you guys try the C6 section?
all three of ya..
00Corvette is offline   Reply With Quote
Old 09-29-2010, 02:12 PM   #17
cdkcorvette7
cdkcorvette7's Avatar
Send a message via AIM to cdkcorvette7
Quote:
all three of ya..
... you know you posted in C5 tech right?
cdkcorvette7 is offline   Reply With Quote
Old 09-21-2011, 09:09 AM   #18
Donnasophia
Junior Member
Default 1998
My handle pulls up but the glove box won't open. It appears that the handle breaks easily, so I'm afraid to force it. At least my proof of insurance card is in the cup holder, however, the pink slip is stuck inside.
Donnasophia is offline   Reply With Quote
Old 09-21-2011, 10:21 AM   #19
87SAM
CF Senior Member
87SAM's Avatar
Quote:
Your car was fired? If you have question, you should start a new thread as this year old thread will get locked down.
__________________
2012 Cyber Gray GS
87SAM is offline   Reply With Quote
Old 09-21-2011, 12:13 PM   #20
Donnasophia
Junior Member
Default What??
And have someone suggest that I do a search because this subject has been discussed previously? Never mind, just close it.
Reload this Page Glove Box Handle Broken - Won't Open - HELP!
Tags
2000, 2007, antonio, box, broken, c5, c6, car, clubs, corvette, glove, handle, open, pictures, san
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
c5 coupes typically leaky? LSUgoTIGER C5 General 34 04-05-2014 12:13 PM
Weights, measurements, ratios, strengths, etc leaftye C5 Tech 252 02-02-2014 12:23 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
