C5 Climate Control bulb replacement
Old 04-26-2009, 10:32 PM
Tony B
Tony B's Avatar
Default C5 Climate Control bulb replacement
Hi All:
Anyone ever had to replace the bulbs behind their comfort controls (Automatic Electronic Dual Climate Control System). 2002 C5 automatic....When the buttons are pushed the orange light comes on, but at night when lights are on you can not see buttons at all...someone has told me that they burn out....my shifter does not light up any more either.... Please help.
Has anyone replaced these tiny bulbs???
Help it is a pain in the rear at night.
Tony "Always Waving"
Old 04-27-2009, 02:24 AM
tstar
tstar's Avatar
St. Jude Donor '11-'12-'13-'14-'15
http://www.mcmaster.com/#1505k414/=1mfct0
You need to replace all of them at once, 14 total. Your shifter takes a 194 bulb which you can replace after you remove the Radio Bezel to gain access to the HVAC unit;
http://www.vetteessentials.com/instr...zel_howto.html
Old 04-27-2009, 08:21 AM
Tony B
Tony B's Avatar
Default Help!!!!
Besides the dealership, who would you recommend to do this job. I can not do it at all......thanks.
Old 04-27-2009, 08:52 AM
poolboy
poolboy's Avatar
http://shop.jwmotoring.com/product.s...5&productId=42
Old 04-27-2009, 02:21 PM
tstar
tstar's Avatar
Supporting Vendor too....
Tim
Old 04-27-2009, 11:42 PM
white90conv
Support Corvetteforum!
white90conv's Avatar
I think you can pry off the bezel with PRND.. on it to replace the shifter bulb. No need to remove the entire console cover. The HVAC controller does require removing the console.
To C5 Climate Control bulb replacement
Quick Reply: C5 Climate Control bulb replacement
