Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-26-2009, 09:52 PM   #1
MN-Brent
CF Senior Member
MN-Brent's Avatar
Default C5 cooling fan power wiring schematic
I'm looking to see if anyone would have scanned or have an electronic copy of the V+ side power routing for the radiator cooling fans.
Im looking to see specifically where the power connection is physically made, and what fusible links or fuses are in the pathway.
I did a MARK VIII electric fan conversion on my C3 last year and used the heavy starter lug as the fan circuit power source. This is a direct battery connection and no fusible links with the very heavy gauge wire. However there is a fusible link from the alternator BAT+ to the starter lug BATTERY + terminal. Not sure if this fusible link is at risk with this set-up.
So the circuit is like this:
FROM BATTERY VIEW:
(BAT+ on Heavy starter lug)-->(New fanwiring with 65A circuit breaker)-->(75A relay)-->(Fan)
FROM ALTERNATOR VIEW:
(ALT BAT+)-->(Fusible link)-->(BAT+ on heavy starter lug)-->(New fanwiring with 65A circuit breaker)-->(75A relay)-->(Fan)
I'm looking to see how GM did it in great detail, whether it was a direct alternator connection and fused from there, or a direct battery V+ connection and be fused from there.
MN-Brent is offline   Reply With Quote
Old 04-26-2009, 09:56 PM   #2
byronhunter
CF Senior Member
byronhunter's Avatar
This what you want?
Click the image to open in full size.
byronhunter is offline   Reply With Quote
Old 04-26-2009, 09:59 PM   #3
lucky131969
lucky131969's Avatar
Send a message via Yahoo to lucky131969
byronhunter, you are getting fast with those diagrams....4 minute response time....
lucky131969 is offline   Reply With Quote
Old 04-26-2009, 10:02 PM   #4
byronhunter
CF Senior Member
Quote:
Yea! Most of the time you beat me to it!!!!!!
Old 04-26-2009, 10:07 PM   #5
fnsblum
CF Senior Member
fnsblum's Avatar
What are you trying to do? Later! Frank
fnsblum is offline   Reply With Quote
Old 04-26-2009, 11:07 PM   #6
MN-Brent
CF Senior Member
MN-Brent's Avatar
Quote:
Originally Posted by byronhunter View Post
This what you want?
Close, but nope.
The power distribution for "Hot at all times" diagram for the fan power circuit.
Do you have that diagram?
Old 04-26-2009, 11:21 PM   #7
Bill Dearborn
Bill Dearborn's Avatar
Is this what you are looking for? B+ not V+ distribution.
Bill
Bill Dearborn is offline   Reply With Quote
Old 04-26-2009, 11:27 PM   #8
MN-Brent
CF Senior Member
MN-Brent's Avatar
Quote:
Im trying to determine where GM pulls its power from for the electric fan circuits.
1) Battery side of fusing
2) Alternator side of fusing
The big difference is the location of the main fuses, which are not included in the diagram attached above.
In the C3, there is a large fusible link between the Alternator BAT+ terminal and the starter heavy lug, which is a direct Battery connection with a heavy gauge wire.
I installed a fan which has a large additional draw and made my connection from the starter lug. Just tryin to see if I should be upgrading my Alternators charge wire from Alt to starter lug or pulling my dedicated fan circuit directly from the Alt connection.
There is logic to both set-ups and Im trying to see which way GM went.
Old 04-26-2009, 11:33 PM   #9
MN-Brent
CF Senior Member
MN-Brent's Avatar
Quote:
Bill
Bill
YES!!!! This is exactly what I needed. A HUGE Thank you for this.
BTW, My next Vette will most likely be a late model 03 or 04 Z06 with the steel shift forks in the tranny. Hope the comeradery on the C5 side is as good as it is on the C3 side.
Thanks again!
Best Regards, Brent.
Reload this Page C5 cooling fan power wiring schematic
Tags
1958, c5, control, cooling, corvette, diagram, ect, electrical, fan, power, relay, schematic, set, top, vette, wiring
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 Tech 252 02-02-2014 12:23 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
