Cam selection for 416 LS3
Old 05-16-2009, 06:33 PM
RonnieLS1
RonnieLS1's Avatar
Default Cam selection for 416 LS3
Just ordered a motor from LME. It is a 416 LS3. I think I went to big on the camshaft. I ordered it with a 244-250 on a 114+3. Lift is right under .650. How is this cam going to behave? Do you think it is over the top? I want something farely aggressive. I only drive the car on Sundays. I have a 3600 stall and 3:73's.
Ron
Old 05-16-2009, 07:23 PM
fst85vtt
fst85vtt's Avatar
Old 05-16-2009, 07:33 PM
Tyler valo
Tyler valo's Avatar
My 418 has a similar cam with .625 lift, it's sorta bad about bucking at low RPM in 5th and 6th, and of course 1st, but other than that no complaints.
Old 05-16-2009, 07:44 PM
WKMCD
WKMCD's Avatar
What heads?
Old 05-16-2009, 07:51 PM
RonnieLS1
RonnieLS1's Avatar
Originally Posted by WKMCD
What heads?
LME's ported CNC LS3 heads. They flow 350.
Old 05-16-2009, 08:41 PM
WKMCD
WKMCD's Avatar
I run WCCH LS3/L92 heads on my 403. I've been through 3 cams and none anywhere near as big as you've got. My current cam is almost 15 degrees smaller than yours. Numbers in sig. Big cams on these heads is a mistake.
Just my $.02
Old 05-17-2009, 10:21 AM
MPM IV
MPM IV's Avatar
That cam isn't to big for those cubes. With a good tune it will drive well. I wouldn't worry about it at all for a weekend toy. How it will work with those heads is a seperate issue that I would get professional advice on. If LME selected it with those heads in mind you should ask what kind of results they've had on similar combos.
Old 05-17-2009, 05:57 PM
Don O.
Don O.'s Avatar
Default Cam
To Cam selection for 416 LS3
Quick Reply: Cam selection for 416 LS3
