B0051 and B1001 code
I need you guys help! I have a '99 coupe and my air bag light just came on and stayed on. I pulled the codes and I got....
B1001 Option cofiguration error
B0051 Deployment commnded
I tried to erase the codes but B0051 won't get erased. I check the fuse (#16) and its all good. What do I check next? Thanks ED
From the Service Manual?????
DTC B0051 Deployment Commanded
Circuit Description
The inflatable restraint sensing and diagnostic module (SDM) contains a sensing device (accelerometer) that converts vehicle velocity changes to an electrical signal. The SDM compares this electrical signal to a value stored in memory. When the generated signal exceeds the stored value, the SDM performs additional signal processing and compares the generated signals to values stored in memory. When two of the generated signals exceed the stored values, the SDM will cause current to flow through the inflator modules, deploying the air bags and causing DTC B0051 to set.
Conditions for Setting the DTC
The SDM detects a frontal crash, up to 30 degrees off the centerline of the vehicle, of sufficient force to warrant deployment of the frontal air bags.
Action Taken When the DTC Sets
The SDM sets a DTC B0051.
The SDM commands ON the AIR BAG warning lamp via Class 2 serial data.
The SDM records crash data.
Conditions for Clearing the DTC
DTC B0051 is a latched code. You cannot clear a latched code. Replace the SDM after following the instructions in the diagnostic table.
Test Description
The numbers below refer to the step numbers on the diagnostic table:
If the inflator module(s) has not deployed, DTC B0051 may have set falsely.
If DTC B0051 has set with no signs of frontal impact, the DTC has set falsely.
DTC B0051 Deployment Commanded Step
Action
Value(s)
Yes
No
1
Was the SIR Diagnostic System Check performed?
Go to Step 2
Go to SIR Diagnostic System Check
2
Turn the ignition switch to the OFF position.
Has the inflator module(s) deployed?
Go to Step 5
Go to Step 3
3
Inspect the front of the vehicle and the undercarriage for signs of impact.
Are there signs of impact?
Go to Step 5
Go to Step 4
4
Replace the inflatable restraint sensing and diagnostic module (SDM). Refer to Inflatable Restraint Sensing and Diagnostic Module Replacement .
Is the replacement complete?
Go to Step 6
5
Install the scan tool
Use the scan tool to request the SIR DTC display.
If a history DTC exists, refer to Diagnostic Aids for that specific DTC and diagnose the problem.
Replace components and perform inspections as required following an accident. Refer to Repairs and Inspections Required After a Collision .
Have the appropriate inspections and repairs been made?
Go to Step 6
6
Reconnect all the SIR system components, make sure all the components are properly mounted.
Have all the SIR components been reconnected and properly mounted?
Circuit Description
Test Description
Action
Value(s)
Yes
No
1
Go to Step 2
2
Go to Step 5
Go to Step 3
3
Go to Step 5
Go to Step 4
4
Go to Step 6
5
Go to Step 6
6
Bumping this becuase I have the same issue.
Anyone ever find a way around going to the stealership to get this fixed? I can replace the faulty sensor but from my understanding I'll still need some tech2 device or something. Any and al input would be great. Obviously I've done a search because I'm bumping a year old thread.
05 corvette with 0051 passenger airbag deployment code?
Hey I have the same code 0051 passenger airbag deployment code, on this 05 corvette i have.I guess it would mean the same thing as your c5, the airbags were never deployed on mine, but what is the SDM you guys are reffering to is that the "airbag module" undetr the center console under the radio? if so do i just need to send that in to the airbag module to reset it?
