Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-02-2009, 11:50 PM   #1
DuffC5
CF Member
DuffC5's Avatar
Default Battery keeps dying but battery and alternator checked out ok!
This is on my Automatic 2000 Coupe. I’ll try to describe my problem the best I can. I bought a new 7 or 8 year battery about 7 months ago because the original finally died and everything has been fine. The whole problem started a few months ago when I didn’t drive it for a month and the battery was dead when I went to start it up so I just charged it with a car trickle charger to about 14 something volts then the car started fine. But now almost every time after I drive it like 30 miles or so when I turn the car off the battery loses charge or volts go down to like 11 or 10 almost right away and the car won't start. I had the battery tested and the alternator and he said they were good although he said the alternator and the battery were both putting out about 14 volts when the car was running and that seems odd doesn’t it? There is no corrosion around the terminals or wires!! What else should I look for? When the battery is charged or jumped the car starts fine!
One other thing I should mention is that sometimes when I pull out of my driveway in reverse then shift to drive the idle goes down and sometimes makes the car stall out. The volts go down when the idle goes down, not sure it that has anything to do with it.
DuffC5 is offline   Reply With Quote
Old 04-03-2009, 02:13 AM   #2
dgrant3830
Wounded Warrior Escort '11
Support Corvetteforum!
dgrant3830's Avatar
Send a message via AIM to dgrant3830 Send a message via Yahoo to dgrant3830
If I was you, I would be looking at the ground connections but especially at the battery cable to starter connection. That connection tends to come lose and will cause problems like this. Its also possible that your battery was killed when it went to full dead as most batteries don't recover from that very well. When you said you had it tested, I'm hoping you meant it was load tested. If it passed a load test, then its probably Ok. Have you tested for something draining the battery? You'll need a DVM or VOM that can measure current and the knowledge to use it. If something is draining it, you'll need to start pulling fuses one at a time till you find the circuit that is causing it and go from there. Pull the codes too just in case.
dgrant3830 is offline   Reply With Quote
Old 04-03-2009, 06:42 AM   #3
RBRBRNR
CF Senior Member
RBRBRNR's Avatar
It may sound simple, but my new Silverado came with a battery that had two bad cells in it. After a couple of months...same issues as you. The Stealership tested it and replaced battery and now no problems.
RBRBRNR is offline   Reply With Quote
Old 04-03-2009, 07:24 AM   #4
Benpup
CF Senior Member
Cruise-In VI Veteran
Benpup's Avatar
Dead cell?
__________________
The beauty of the Second Amendment is that it will not be needed until they try to take it.
I have never been able to conceive how any rational being could propose happiness to himself from the exercise of power over others.
Tyranny is a total failure of government and must be fought against by all means available.
Benpup is offline   Reply With Quote
Old 04-03-2009, 08:32 AM   #5
jimcork1
CF Senior Member
jimcork1's Avatar
Quote:
Originally Posted by Benpup View Post
Dead cell?
Yes I also believe it is a dead cell.! Replace the battery,, the car is ok.
jimcork1 is offline   Reply With Quote
Old 04-03-2009, 11:50 AM   #6
Bob Lobblah
CF Member
Bob Lobblah's Avatar
I am having similar issues as well. I am keeping my car in a storage container for the time being and after i accidentally left my radar plugged in and completely killed the battery I went and bought a new one. Drove the car for the day and then put it back into storage for a couple months (making sure nothing was left plugged in). Went to drive it a week ago and when I got in the car acted normal but when i turned the key it just clicked like a dead battery. Put the cables on it and it started just fine. Initially the volts inside the car were around 13.4 but as i drove it the volts slowly dropped to around 13 after around 30 minutes. After the drive I turned the car on and off 5 or 6 times and it started just fine. Since i had no time to work on it I just unhooked the battery for now and left it till next time. Any suggestions would help?
Bob Lobblah is offline   Reply With Quote
Old 04-03-2009, 12:09 PM   #7
dgrant3830
dgrant3830's Avatar
A lot of people seem to think that if everything is turned off, there is no battery drain. Unfortunately this is not the case. There is always a drain although it should be very small in the low milliamps, but it is always draining. You can't let it sit for months without re-charging or putting a battery tender on it. I remember a post in this forum too that a very knowledgeable person with batteries made a good case as to what happens when you drain even a brand new battery to zero... the thing is trashed permanently.
Drive your cars. Keep it charged up by whichever method you choose, driving it or battery tenders.
Old 04-03-2009, 12:35 PM   #8
DuffC5
CF Member
DuffC5's Avatar
Thanks for the help guys I'll check it out today. I forgot to say the new battery is a AC Delco.
Reload this Page Battery keeps dying but battery and alternator checked out ok!
Tags
1984, 2004, alternator, battery, c3, car, chevy, corvette, dieing, drain, dying, passes, silverado, stall, test
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
