Rocking seat fix
Search "rocking seat fix" there probably are well over 100 posts on the subject, that is how I found them.
EDIT.... Search feature really sucks here cause now I cant find the posts. I searched, rocking seat fix, rocking, seat fix and they all came up with 10 pages of posts to sort through. I searched in the C5 forums only.
Try this link, I dont know why it wont search better than this.
http://forums.corvetteforum.com/sear...rchid=10085512
You’re "right on" MagRedConv – Links below to help the “search challenged” ----
It is in the “Ultimate DIY Thread” as MagRedConv stated.
It is called “Rocking Seat Fix” in the intro – the post, listed in the intro is ONE POST NUMBER OFF –
Links below to help the “search challenged” ---- ALL THREE PAGES ---
http://www.lieblweb.com/TechLinks/Co.../C5SeatFix.htm
http://www.lieblweb.com/TechLinks/Co...C5SeatFix2.htm
http://www.lieblweb.com/TechLinks/Co...C5SeatFix3.htm
EDIT - All this typing and xboxexpert beat me to it
Location: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Fix worked great for me. Some have reported less than stellar results. In my case the rubber on both sides of the blocks was totally gone so that was the problem.
guys my driver side seat doesnt respond to any of the controls its stuck in front and i want to move it back, its not the wiper remote control because i plugged it in the other side and its perfectly fine on the passenger side.
I jsut fixed mine last week with the nylon washers....not rocking AT ALL, seats are like new again....My rubber stoppers were completely disintegrated, all was left was dust!!
Follow the isntructions, dont leave any loose space in the little metal box, and u will have no rocking seat!
There is another problem that can cause the seat to rock. On mine, the rubber parts were perfect. But one of the motors was a bit loose where it attaches to the frame of the seat. I managed to tighten it a bit but the problem came back.
1 Post
Got the parts to fix mine, but I'm looking at the DIY fix and going DAYUM! I'm not sure if this is what's wrong with mine or not. I wouldn't say mine rocks, more like slides forwards on braking and then backwards on acceleration. It seems like it moves an inch or more in each direction. Those washers are only 1/8 inch thick, so if they were gone, wouldn't you only have 1/8 in movement?
