99 FRC Water Pump
St. Jude Donor '07
99 FRC Water Pump
Does anyone have expirence with installing an LS3 water pump on an LS1? I bout the pump from Fichtner, and it looks like the upper hose is not compatible, also, do the older LS1 pumps use paper gaskets? The new one came with o-ring gaskets, I did a forum search before I purchased the pump, and found a couple guys had done this, but the details were kind of vague, any help would be appreciated.
what about the upper hose doesn't look compatible? did you resolve your issue?
Your engine has the silicone/aluminum gaskets just like the replacements.
