Sway Bar Diameters
Sway Bar Diameters
I did a search and cant find the info.
I have a 98 Coupe that had the Front sway, shocks and springs replaced with 04 Z06 parts but the rear sway looks stock. Does any one have a list of sway bar diameters? Even some diamters from the C6 cars to see what the difference is (if any).
Thanks for the help!
Jimbo
Jimbo
1 Post
FOUND THIS IN SEARCH
All second hand info, mostly collected from the forums here.
Swaybars:
* C5 Base Suspension: 23 mm-front / 19.1 mm-rear / 3.81mm/2.0mm thickness
* C5 Z51 (97-99): 25.4 mm-front / 21.7 mm-rear
* C5 Z51 (00-04): 28.6 mm-front / 23.6 mm-rear / 4.15mm/3mm thickness
* C5 Z06: 30.0 mm-front / 23.6 mm-rear / 4.5mm/3.5mm thickness
* C6 Base: ?? mm-front / 22.0 mm (7/8")-rear
* C6 Z51: 31 mm-front / 25.4 mm (1")-rear
* C6 Z06: 31 mm-front / 28.8 mm-rear
* C5 Hotchkis: 31.75 mm-front / 25.4 mm-rear / 4mm/4mm thickness
* C5/C6 Addco: 32 mm-front / 25.4 mm-rear
* C5/C6 Addco: 35 mm-front / 25.4 mm-rear
* C5 Pfadt (Adjustables): 32 mm-front / 26 mm-rear http://www.pfadtracing.com/
* C5 Pfadt (Adjustables): 35 mm-front / 28.5 mm-rear (Pfatty)
* C5 T1 (GM Racing): 38.4 mm-front / 27.5 mm-rear / 6.35/6.35 thickness
* C6 T1 (GM Racing): 38.4 mm-front / 27.5 mm-rear / 6mm/?? thick
Springs:
* C5 Z06: 526# Front, 714# Rear
* C6 Z06: 531# Front, 782# Rear
* C6 Z51: 526# Front, 645# Rear
* T1 (C6): 582# Front, 850# Rear
* C6 Base: 420# Front, 657# Rear (VBP: 400-420 F / 600-620 R)
* T1 (C5): 582# Front, 793# Rear
* Pfadt Coil-overs: 425# Front, 575# Rear (Remember: Wheel rates!)
* Hyperco HPS (Street): 565# Front (12405HPS), #765 Rear (12406HPS)
* Hyperco HPT (Track/Solo): 625# Front (12407HPT), #850 Rear (12408HPT)
* VBP Sport 990# Front, 650# Rear
* VBP Extreme 1050# Front, 855# Rear
Swaybars:
Springs:
The following 2 users liked this post by slothy:
Docwade (02-25-2020),
StancyPants (01-26-2017)
