Damned Torque Tube bolts
Former Vendor
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
I am having hell getting the 50 Torx head bolts out of my torque tube. I have a 240 lbs impact wrench but they are still not breaking loose. They have a TON of blue lock tite on them. Is there anything I can do to loosen these things up? I got 4 out of 12
Now you tell me,lol! I have to unbolt mine too. Something to look forward to I guess.
Former Vendor
Dude those things are in there. My compressor is 140 psi and my impact is 240 ft lb. I really thought that would take them out but NOOOOOOO. I have figure out how to apply heat to the bolt only? There has got to be a trick to this?
Location: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Use a heat gun. The steel bolt will heat hotter and faster and retain heat more than the aluminum.
Them bolts are welded in with blue loc-tite. The heat method of torch works well. I've done it a number of times.
I did mine with a 1/2 inch ratchet and a cheater bar....worked great.
Former Vendor
Ya the bolts have a solid 1.5 inches of blue locktite on them. I went and got a CN 425 lb impact wrench today. I will get a torch tomorrow and heat the bolts up and break em loose. Thanks for the help guys. I love this place.
Former Vendor
I went out and got a 425 ft lb double hammer impact wrench..........twisted the remaining torx head bolts out like nothing. Very happy now
Cajun
Cajun
