Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-23-2009, 08:47 PM   #1
magnetized
CF Senior Member
St. Jude Donor '09
magnetized's Avatar
Default How do you remove this piece of the sun visor (pic)?
Click the image to open in full size.
I'm swapping my old broken sun visors for some new pristine sunvisors and I can't get this bezel/clip off the old ones to swap over. Any help is appreciated
magnetized is offline   Reply With Quote
Old 01-23-2009, 10:43 PM   #2
c5blkvetteguy
CF Senior Member
c5blkvetteguy's Avatar
That part stays on the end of the visor. Just undo the wire.
c5blkvetteguy is offline   Reply With Quote
Old 01-24-2009, 12:29 PM   #3
magnetized
CF Senior Member
St. Jude Donor '09
magnetized's Avatar
Quote:
The sunvisors are removed, unclipped, etc. I need to swap the circled bezel off of the old sun visors.
Old 01-24-2009, 04:50 PM   #4
Bill Dearborn
Bill Dearborn's Avatar
Looking in the Service Manual its supposed to be easy. Here are the complete instructions for replacing the sunshade.
Sunshade Replacement
Removal Procedure
  1. Click the image to open in full size.
    Tilt the sunshade down toward the windshield.
  2. Insert a flat head screwdriver blade into the slot in the sunshade inner bezel.
  3. Using the screwdriver against the elbow of the sunshade arm for leverage pull down on the sunshade arm while rotating the sunshade outboard until the sunshade stops. (the first tab disengages).
  4. Push up on the sunshade and continue rotating the sunshade outboard until the sunshade with the inner bezel disengages from the mounting bezel.
  5. Disconnect the electrical connector.
  6. Remove the sunshade.
  7. Disassemble as necessary.
    • If removing the mounting bezel, pull the bezel from the garnish molding with your fingers.
    • If replacing the inner bezel, remove the bezel from the sunshade shaft and press the new bezel onto the shaft.
Installation Procedure
    Route the harness through the mounting bezel.
  2. Insert the mounting bezel into the garnish molding engaging the snap fingers.
  3. Connect the harness to the sunshade electrical connector.
  4. Push the connector up through the bezel and through the hole in the garnish molding.
  5. Position the sunshade approximately midway between the windshield and the side of the vehicle.
  6. Insert the rod with inner bezel firmly attached fully into the mounting bezel.
  7. Rotate the sunshade toward the centerline of the vehicle until the sunshade locks in place.
Like I said its supposed to be easy but there are no specific instructions on how to remove that bezel.
Bill
Bill Dearborn is offline   Reply With Quote
Old 01-24-2009, 06:00 PM   #5
dougbfresh
CF Senior Member
The bezel came on the last one I ordered new. Not sure you even can remove it after assembly. Where did you get the visor(s) from?
dougbfresh is offline   Reply With Quote
Old 01-25-2009, 03:23 PM   #6
magnetized
CF Senior Member
St. Jude Donor '09
magnetized's Avatar
Quote:
Bill
That will help, thanks
Quote:
I got them from a member, I'm going to pm them and see how they were able to get them off.
Old 01-26-2009, 09:55 AM   #7
runamuk
CF Senior Member
Cruise-In V Veteran
St. Jude Donor '04
runamuk's Avatar
Quote:
I also order some sun visors new from GMPartshouse.com and they came with the bezel attached.
runamuk is offline   Reply With Quote
Old 08-05-2010, 07:34 PM   #8
Dukenukemx
Junior Member
Dukenukemx's Avatar
Anyone have the part # for the Sunshades? I wanna to get some new ones from GMpartsdirect.
Dukenukemx is offline   Reply With Quote
Old 08-05-2010, 09:32 PM   #9
FLYNAVY30
CF Senior Member
FLYNAVY30's Avatar
Send a message via AIM to FLYNAVY30
If you want mine, I can send them to you in a week or so...Im redoing my headliner and getting rid of the visors entirely because Im so tall, it improves my field of view, and I never use them anyway
FLYNAVY30 is offline   Reply With Quote
Old 09-08-2010, 01:40 AM   #10
arcticZ51
CF Senior Member
arcticZ51's Avatar
Send a message via AIM to arcticZ51
Quote:
I'd like to remove mine as well but what do you do with the hole that's left behind? TIA
arcticZ51 is offline   Reply With Quote
Old 10-26-2010, 11:27 AM   #11
jbalas
Junior Member
Default Need Driver's Side Visor
Looking for a driver's side visor for a C-5 (2003). Anybody? FLYNAVY30?
Former Squid
jb
jbalas is offline   Reply With Quote
Old 11-05-2010, 12:56 PM   #12
British
CF Senior Member
British's Avatar
Looks like a good writeup, I'm going to need to do this myself probably... My mirror popped off and it's just dangling... There doesn't seem to be a good way to glue it back on there.
British is offline   Reply With Quote
Old 11-05-2010, 08:46 PM   #13
Sting99
CF Senior Member
Sting99's Avatar
That bezel broke on my Driver's side visor. I did not see a part number? Is it replaceable or do you have to get a complete visor? I noticed that on the instructions it explains how to slide the visor thru the bezel?
Please advise
Sting99 is offline   Reply With Quote
Old 12-09-2010, 08:47 PM   #14
billyward
Junior Member
Default 1998 corvette triangle locking devices
how can i find two of these triangle locks and bezzells?. my visors are like new but the triangles and bezzels are broke. some one tried to steal my visors and jerked them out of the ceiling breaking the locks and triangle devices. please answer!
billyward is offline   Reply With Quote
Old 12-09-2010, 08:55 PM   #15
billyward
Junior Member
there is got be a way to get 1998 corvette visor locking devices.
Old 12-09-2010, 09:00 PM   #16
billyward
Junior Member
are those triangle locks called inter bezzells?
Old 12-09-2010, 09:20 PM   #17
billyward
Junior Member
Default inner bezel
i need a couple of those inner bezels you are trying to get off. where can i get them?
Old 12-09-2010, 09:23 PM   #18
billyward
Junior Member
if any one knows how to find inner and outer bezels for a 1998 corvette visor please reply!
Old 02-24-2011, 09:33 PM   #19
92GA
CF Senior Member
Oldtimer
92GA's Avatar
I just replace my visors with new ones I bought off of E-Bay. They were supposed to be gm, I don't know about that but they fit perfect. Just for the heck of it I removed the locking bezels. They were in a warm garage, but I just opened my vice a little, so not to hold tight, and taped the part where the wire come through and the bezel came right off. No damage.
92GA is offline   Reply With Quote
Old 08-22-2012, 02:24 PM   #20
shwtrkman
Junior Member
Do you still have the visors? I thought the visors with lighted missors were stock but the C5 I just bought does not have them. I would also need the clips they attach to. One of mine is broken.
shwtrkman is offline   Reply With Quote
Reload this Page How do you remove this piece of the sun visor (pic)?
Tags
2002, c5, c6, connection, corvette, electrical, removal, remove, removing, replace, sun, sunvisor, vette, visor, visors
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
How to align a roof panel Scoob C4 General Discussion 25 11-03-2011 11:30 AM
TargaGlass Top installation ZR-1DUDE C4 ZR-1 Discussion 10 02-10-2003 11:53 AM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
