Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-12-2009, 11:01 AM   #1
facc5
Junior Member
facc5's Avatar
Default EBCM "pump on" problem
I plan to send the EBCM from my 2001 Vette coupe to Brandon at ABS fixer. On the EBCM repair form, the question is asked whether the module is experiencing the "pump on" problem.
How do I know whether the EBCM is experiencing the "pump on" problem?
facc5 is offline   Reply With Quote
Old 01-12-2009, 11:22 AM   #2
dgrant3830
Wounded Warrior Escort '11
Support Corvetteforum!
dgrant3830's Avatar
Send a message via AIM to dgrant3830 Send a message via Yahoo to dgrant3830
Taking a guess here is that he's asking if it works at all or not? I'm guessing you got a code stating a problem. While its in the car, a cheater's way of testing it is to deliberately spin the wheels. See if the DIC reports the Traction/Active Handling coming on and listen for the sounds of it running. It will probably sound like clicking.. .I think....and you should feel it in the brake pedal.
dgrant3830 is offline   Reply With Quote
Old 01-12-2009, 04:22 PM   #3
facc5
Junior Member
facc5's Avatar
I've been getting the C1214 code. I have no reason to believe that there is a problem with the pump in the system, so I guess I'll answer no on the form.
Old 01-12-2009, 04:27 PM   #4
lucky131969
lucky131969's Avatar
Send a message via Yahoo to lucky131969
Quote:
Wouldn't it be easier to just inquire with Brandon?
lucky131969 is offline   Reply With Quote
Old 01-12-2009, 08:23 PM   #5
facc5
Junior Member
facc5's Avatar
I tried e-mail, but he did not answer. Maybe I'll give it a second try.
Old 01-13-2009, 09:56 AM   #6
facc5
Junior Member
facc5's Avatar
My bad! I e-mailed Brandon at ABSfixer yesterday and he responded this morning by stating the "pump on" problem applies only to GM trucks and SUV's. Problem solved.
Old 01-13-2009, 10:47 AM   #7
chaase
CF Senior Member
St. Jude Donor '12
chaase's Avatar
I had the C1214 code and the rebuild worked for me.
chaase is offline   Reply With Quote
Old 01-13-2009, 11:18 AM   #8
The Wrench
CF Senior Member
FACC5, just a suggestion: the ABS motor gets pretty gummed up after years of minimal use. While you have the module separated, why not do a little ABS motor "excercising". Just supply a fused 12 volts to pin #8 on the hydraulic module (the one you didn't remove) and the motor will run.
Do a few 2-3 second bursts, and you should hear the motor begin to loosen up. Then do a few 10 second runs to really clean it up.
I just did this this week, and I could tell the motor was pretty gummed up from lack of use; it started slow but finished fast, with much less current draw.
Check my recent thread on it. search C1243 (the Wrench).
DG
The Wrench is offline   Reply With Quote
Old 01-13-2009, 11:33 AM   #9
facc5
Junior Member
facc5's Avatar
chaase- I'm very glad to hear that the rebuild worked after getting the C1214 code. Did ABSfixer do the repair? If so, did you get the surge suppression option?
DG- Since I won't be removing the EBCM myself, I'll let my mechanic know about the ABS motor and see if he can "exercise" it as you described.
FC
Old 01-13-2009, 11:40 AM   #10
chaase
CF Senior Member
St. Jude Donor '12
chaase's Avatar
FC
I did have ABSfixer do the repair and did all the work myself at home in my garage. I didn't see the surge suppression option, so I didn't get it.
Reload this Page EBCM "pump on" problem
Tags
chevy, corvette, ebcm, problem, pump, suppression, surge
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
