Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-20-2008, 02:34 AM   #1
Valdostavetteguy
CF Senior Member
Support Corvetteforum!
Valdostavetteguy's Avatar
Default Sears 50/10/2 battery Charger...was this a good buy?
I go 2-3 weeks at a time in between engine starts and I want to keep the battery level up.
Does anyone have one of these and do you set yours on the 2 Amp trickle charge in between starts?
Is it ok to set it at 10 amps for a quicker charge 3-4 hours when the battery is low?
Also, where do you connect the negative clamp? On the engine block? where?
I may need to replace the battery...will pulling the battery completely out affect the PCM? My car is a H/C car and has a custom tune in the PCM that I don't want to lose.
I have a NASCAR XLT gel battery model NXDT34
Thanks in advance!!!
Valdostavetteguy is offline   Reply With Quote
Old 12-20-2008, 04:52 AM   #2
dieseldave56
CF Senior Member
dieseldave56's Avatar
Default DieHard model 200.71222
Son , do you have this model ? 200.71222[IMG]Click the image to open in full size.[/IMG]
It is a very common Sears Diehard Automatic battery charger. This is not a battery maintenance charger, which is what you need for long term , walk away battery maintenance. Battery Tender , floating charger is what you need for maintenance. The Diehard will not shut off when the battery is fully charged and if left on in that condition can damage your battery.
The Sears Diehard Automatic charger 2/10/50 is to be used ONLY on LEAD - ACID batteries , NOT Gel or AGM.
Do you have the Sears battery charger manual? PM me if you need one.
To slow charge a low battery at 2 amps , I've never had problems just connecting the charger to the in car battery while cables are connected. But with 10 amps , I disconnect negative battery cable before charging.
You can make the negative charger connection at either the battery terminal or engine/ frame., but I personally connect to the terminals. Always connect the negative last and disconnect first to avoid a possible spark as a matter of practice.
No , you will not lose your tune.
dieseldave56 is offline   Reply With Quote
Old 12-20-2008, 08:45 AM   #3
aleadfoot
CF Senior Member
It is a pain but disconnect the neg terminal when you shut her down for a couple weeks but the battery wont drain down. I agree that you shouldnt leave anything but an automatic charger connected for long periods
aleadfoot is offline   Reply With Quote
Old 12-20-2008, 10:00 AM   #4
tabbruzz
CF Senior Member
tabbruzz's Avatar
A CTEK 3300 is the way to go..........I love mine...
tabbruzz is offline   Reply With Quote
Old 12-20-2008, 10:31 AM   #5
Valdostavetteguy
CF Senior Member
Thanks guys! Yes, that's the one I have. I'll take it back because both my batteries (daily driver) are gel.
Then I'll get a battery tender.
This forum rocks!
Old 12-20-2008, 11:09 AM   #6
Bville-Bud
CF Senior Member
St. Jude Donor '05-'06-'07-'08
Bville-Bud's Avatar
Quote:
I got one from Chip (forum vendor) he had it to me amazingly quickly and it works great!
Bville-Bud is offline   Reply With Quote
Old 12-20-2008, 11:19 AM   #7
Quick Silver Z
CF Senior Member
No-IL Events Coordinator
St. Jude Donor '12-'13-'14
Quick Silver Z's Avatar
I also have a http://store.schumachermart.com/5216a-pe.html but I only use that for an occasional "jolt"!
Quick Silver Z is offline   Reply With Quote
Reload this Page Sears 50/10/2 battery Charger...was this a good buy?
Tags
10, 20071222, amp, automatic, battery, buy, charge, charger, diehard, hours, manual, model, nascar, nxdt34, owners, performance, sears, series, xlt
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
