Legendary Problem Solved....
Old 12-18-2008, 10:37 PM
C599
C599's Avatar
Default Legendary Problem Solved....
Must be Xmas time. I figured out the issue with the famous key fob problem of it loosing sync with the cars. Turns out it's a problem with one of the chips coming detached from the circuit board.
When you open the key fob with the board facing you, look near the top right hand corner. There's a rectangle shaped chip, check the prongs. I checked mines both times when each of my remotes wouldn't keep sync with the car, each time it was loose.
I resolder it or you can even use permanent glue between the chip & board to hold it firm if you're not comfortable with soldering. Make sure the prongs have a good connection. Sorry that I haven't taken any pics, but it's pretty much straight forward.
Yeah, I know my atar is big, but I put it in at normal size & it keeps blowing up to the huge size. Yeah, I've resized it, lower resolution. I'll play with it some more later when time permits.
The following 4 users liked this post by C599:
ArmchairArchitect (05-18-2017), El original (11-15-2016), jlaw1313@comcast.net (05-31-2017), Zo&Shel (10-17-2016)
Old 12-19-2008, 04:15 PM
Fasthotrod
Fasthotrod's Avatar
That would make sense... I just took mine apart and studied the circuit. It appears that one of the battery (+) legs goes up to the two legs on that chip, through the chip, then down to two pins on the main chip.
Maybe that is a memory feature of some kind? I think the FOB's have a rolling code, so maybe this is what keeps track of the codes as it rolls over?!?!
I just took my FOB down to the lab and hit those points with some solder. If it works, I'll report back.
Thanks for the tip.
Mark
mrmojo37 (07-12-2023)
Old 12-19-2008, 07:55 PM
Fasthotrod
Fasthotrod's Avatar
TOUCHDOWN!
I have had no problems with my FOB since this fix. Thanks again for posting this information!
Mark
Old 12-30-2008, 10:55 PM
Fasthotrod
Fasthotrod's Avatar
I took a picture of the FOB and the six points that that I re-soldered. The points are marked with red dots.
You need a small tipped iron to get down on those points... but it's better than buying a new FOB.
Mark
The following 2 users liked this post by Fasthotrod:
joelschl (07-19-2020), saxtech (03-28-2017)
Old 12-31-2008, 08:07 AM
ecoman
ecoman's Avatar
Great info thanks
Old 01-20-2009, 11:37 PM
cobrachuck
cobrachuck's Avatar
Default Cool info
Guys Thanks
I just bought a 2000 coupe key fob never worked. I will check when I get home this week
Chuck
slammer46 (05-13-2016)
Old 02-14-2009, 10:21 PM
doje
Support Corvetteforum!
doje's Avatar
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Awesome
Old 02-15-2009, 12:17 AM
Mike Mercury
Mike Mercury's Avatar
great find !!!
Old 02-15-2009, 12:21 AM
madmatt9471
madmatt9471's Avatar
Location: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
XLNT! It just goes to show you that you learn something new every day
Thanks,Matt
Old 02-15-2009, 07:01 AM
csexton
csexton's Avatar
Good info
Chuck
Old 02-15-2009, 09:44 AM
rws.1
rws.1's Avatar
thanks for sharing
Old 02-17-2009, 11:10 PM
vetfeva2
vetfeva2's Avatar
I'll be damn if I didn't just receive my new remote today then read this post and found the same thing. Oh well, I have a brand new spare now.
Old 03-09-2009, 11:53 AM
my6thvette
my6thvette's Avatar
Default This really works.
I had been having problems with my 1999 fob for some time. Replaced the battery and still no improvement. About every day I had to resync the fob in order to get it to work. After reading this post, I opened the fob and examined the chip connections but could not see that they were actually loose. Some days later I decided to go ahead and try the repair described in this post. The fob now works perfectly. Not only does it retain sync, but even the slightest tap of the fob buttons brings an instant response. If you are experiencing problems with your older key fob, give this a try.
Old 03-09-2009, 01:04 PM
HRDTOPC54FUN
HRDTOPC54FUN's Avatar
C599 - great info - I'm going to give it a try, thanks for the post.
Old 03-09-2009, 01:14 PM
itzza427
itzza427's Avatar
This needs to be a sticky,,,right along with the dim/dark HVAC display fix!! Have to remember this one too!! I have so many bookmarks now that I can't find the ones I looking for now!!
Old 03-09-2009, 05:06 PM
jedblanks
jedblanks's Avatar
If anyone ends up with an extra 97-99 (passive mode) fob over this deal, I'd be interested in it.
Old 03-09-2009, 05:10 PM
IrishMac
Moderator Emeritus
IrishMac's Avatar
Gone, but not Forgotten
Cruise-In 5, 6, 8 & 10 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09
No way in hell could I solder that. I don't have the steadiest of hands.
To Legendary Problem Solved....
Old 03-09-2009, 06:51 PM
TUF-NUF
TUF-NUF's Avatar
Location: kent ct - "if i'm not in the vette, i damn well better be on the yacht."
St. Jude Donor '13
God, I love this forum.... ( I also love saving $$$$$)
Old 03-09-2009, 07:24 PM
my6thvette
my6thvette's Avatar
It's actually quite easy. It took me about 2 minutes to do it. It is easier if you first remove the rubber gasket surrounding the circuit board. Just use a sharp tip soldering iron and barely wet the tip with fresh solder before touching the 4 chip connection point.
Old 03-09-2009, 09:28 PM
00Corvette
00Corvette's Avatar
Would the glue actually work the same or is it way better to solder it?
Thanks so much!
Just curious because a super glue tip is perfect for that tight spot...
Donnie
Quick Reply: Legendary Problem Solved....
