2001-2004 key fobs- not your typical question
Old 12-12-2008, 11:55 PM
TGstring
TGstring's Avatar
Location: cruising between USA and Canada... SAVE THE WAVE!
Default 2001-2004 key fobs- not your typical question
Hello,
I've searched in and out and cannot find a clarification on the following:
I have a 2001 tpms/remote entry RECEIVER and it clearly says:
FCC ID: KOBLEAR1XR
and
I understand all the '01-'04 key fobs are GM PN: 25695954
and
they're all over ebay for $5 each
BUT
THEY ARE ALL:
KOBLEAR1XT
even though they have the same p/n, does anyone know for sure if the KOBLEAR1XT will work??
I don't want to get stuck with something that will be a paperweight.
All your guidance is appreciated!
TGstring
Old 12-13-2008, 07:26 AM
65GGvert
65GGvert's Avatar
Received 3,238 Likes on 2,313 Posts
T= transmitter (fob)
R= receiver (in car)
They're the right ones.
Old 12-13-2008, 07:33 AM
65GGvert
65GGvert's Avatar
I was just looking at your profile. In your biography it says your car started life in 2007. I am assuming you meant 1997 since you say it made it's way to Canada 11 years later.
I also assume since you're looking at the newer fobs and the receiver is from a 2001 that you are changing out the older system. If so, please post how it goes. Several people are interested in doing that to get the newer, cheaper fobs and tps sensors.
Old 12-13-2008, 06:28 PM
Quicksilver Vert 01
Quicksilver Vert 01's Avatar
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Default '01 Factory Key Fob Numbers
My original '01 Key Fob reads: GM/LEAR 25695954
FCC ID: KOBILEAR1XT
The ones on eBay should be fine.
Old 12-14-2008, 03:32 AM
TGstring
TGstring's Avatar
Default Thanks- that's just what i needed!!
you truly are golden!
thanks for the insight- it never occured to me
I'll certainly let everyone know how it goes.
Old 12-14-2008, 04:03 AM
TGstring
TGstring's Avatar
FCC ID: KOBILEAR1XT
thank you!
To 2001-2004 key fobs- not your typical question
Quick Reply: 2001-2004 key fobs- not your typical question
