What is Toluene and where do you get it?
Old 01-16-2002, 08:16 PM
ICULUKN-C5
ICULUKN-C5's Avatar
Default What is Toluene and where do you get it?
What is Toluene and where do you get it? Does it really boost octane?
Old 01-16-2002, 08:18 PM
intel55
intel55's Avatar
Default Re: What is Toluene and where do you get it? (ICULUKN-C5)
it is a solvent and boosts octane... you can get it at Ace or Home Depot, probably other places. It really does boost octane. Big time. :cheers:
oh yeah at Ace it is under the Toluol name... xylene is jsut about the same thing...
[Modified by intel55, 6:19 PM 1/16/2002]
Old 01-16-2002, 08:24 PM
ICULUKN-C5
ICULUKN-C5's Avatar
What is the dilution ratio. How much Toluene per gal?
Old 01-17-2002, 12:56 AM
sandyg
sandyg's Avatar
Be careful with that stuff. It has a high flash point and the vapors can cause brain damage if inhaled!!!!
Old 01-17-2002, 01:14 AM
intel55
intel55's Avatar
I mix one gallon of toulene with 5 gallons of 93 octane gas. :cheers:
Old 01-17-2002, 01:24 AM
RatRacer
RatRacer's Avatar
Default Re: What is Toluene and where do you get it? (intel55)
I run 1 1/2 gallons of toluene with 8 1/2 gallons of 93 octane pump gas. You should add only as much as is necessary to prevent detonation. Don't run over 20%. I only use it when I run nitrous because I don't need that much octane without the juice.
It is a primary ingredient in pump gas so don't worry about it harming O2 sensors or cats. Toluene is 114 octane. I get it at a local paint supply house for $5.50 a gallon.
[Modified by Cam Potter, 11:28 PM 1/16/2002]
To What is Toluene and where do you get it?
Quick Reply: What is Toluene and where do you get it?
