ABS module question
Old 11-21-2008, 12:56 PM
2kvert
2kvert's Avatar
Default ABS module question
I have an 02 with the 1214 code popping up for the ABS/traction/active handling. I know that it is a stuck relay or solenoid by description. My question is are these module compatible between years and if so which ones? Also, how do you identify one module from the other as in markings, serial number, part numbers by year models?
knockingdiesel (01-10-2021)
Old 11-21-2008, 01:27 PM
Evil-Twin
Evil-Twin's Avatar
Received 3,812 Likes on 1,925 Posts
St. Jude Donor '03-'04
serial numbers are different for different years... the absfixer can fix your problem. you can remove it from your car and still drive it.,..while it is being fixed.
Old 11-24-2008, 07:44 AM
FiberglassFan
FiberglassFan's Avatar
Please also check the connections between the wheel speed sensors, built into each wheel bearing, and the harness...Te contacts will spread in time and not make good connection, causing either, or both ABS and Traction Control shutdown...I saw a thread here on CF on the subject that had some good photos of what to do inside the connector to pusch the metal parts back so that they make good contact with the mating part...Sorry, I don't have that thread..perhaps a search would find it for you...After checking/adjusting the connections and it still fails, THEN send the control unit off for rebuild.
I'm right in the middle of all this myself!
Old 11-24-2008, 08:33 AM
trussme
trussme's Avatar
Default here you go..
FIRST! if you want the photos referred to in this tutorial, PM me your email address
The Basics
Let's cover some basic information on AH, TC, and ABS. In simple terms, these three systems combine data from wheel speed sensors, yaw rate sensors, steering wheel position sensors, along with brake and throttle inputs to determine what the driver wants to do and detects any lose of traction and take corrective action by pulling back on the throttle, activating brakes on individual wheels, or releasing brake pressure as needed to maintain traction.
What goes wrong?
When there is a problem anywhere in the system, the computer does not know what's going on with the car or cannot respond correctly. Rather than risking the wrong response, which could potentially wreck you car, the whole system is simply disabled for the remainder of the ignition cycle. At this time you will see the ABS and Traction Control warning indicators illuminated on the instrument cluster along with the following messages on the Driver Information Center (DIC):
- Service ABS
- Service Traction System
- Service Active Handling
At this point, you can safely continue to drive your car, just remember that your electronic driving aids are no longer functioning so you should adjust your driving habits accordingly.
Troubleshooting
As I said before, when there is a problem the system is deactivated for the remainder of the ignition cycle, so sometimes everything will go back to normal if you just turn off the car and restart it. If that corrects the problem, it was either a glitch in the system, a lose connection that's going to come back soon or an early sign of a future failure that is coming. Even though the system is now functional it is still beneficial to continue to trouble shoot. The history code should give you a good idea of what to check
The next step is to see where the fault is. If you have several different codes write them down, clear them, and see which ones come back the next time you start the car. At this point, I'm betting that the codes point to either the EBCM or the wheel speed sensors. We'll get to the wheel speed sensors later, for now, let's get to the EBCM.
THE SYSTEM
The "system" that provides functions such as Anti-lock Braking and Traction Control is made up of two major parts ... the EBCM (Electronic Brake Control Module) and the BPMV (Brake Pressure Modulation Valve).
EBCM - This is the computer that receives input from sensors such as the wheel speed sensors (one sensor per wheel) and then decides when and how to "intervene" to unlock a wheel that has stopped spinning under heavy braking, for example. The most common code for the EBCM is C1214 - Sol Valve relay Contact or coil CKT Open. This code is set when the system voltage is less than 8 volts for 0.23 seconds.
BPMV - This unit has a pump and a series of valves. It is connected to the brake lines from the Master Cylinder and is then connected to the four brake calipers.
Under normal braking the BPMV valves are "open" so that brake fluid just passes straight through it and the calipers respond to your foot pressure on the brake pedal.
Should the EBCM decide it wants to take control of a caliper, say for ABS, the EBCM starts the pump in the BPMV and using solenoids it can change the valve layout so the EBCM can control brake pressure to that caliper. Using the pump and valves the EBCM can use the BPMV to decrease and increase brake line pressure to that caliper.
The C1214 indicates that the relay inside the EBCM that powers up the BPMV pump and the solenoids in the BPMV has failed. Without this relay the EBCM cannot power up the BPMV components when needed. That is why the C1214 causes the loss of all the systems that require control of brake line pressure. You have lost ABS, Traction Control, and Active Handling. You have also lost Dynamic Rear Proportioning and Rear Stability Control if your car is a 2001 or newer, though you won't see warning messages for those systems.
Since our goal is to fix this for the lowest price possible, we'll start checking things we can fix for free.
The EBCM sits between the engine and radiator.
You can see it in the picture on the below. The EBCM is on the left with the large wire harness coming into it and the sticker on top. The Brake Pressure Modulator Valve (BPMV) in on the right with the brake lines coming out. The EBCM is a dry module, meaning that you can change it out without having to worry about bleeding the ABS system. All of the brake fluid is contained within the BPMV (Figure 1 – EBCM (Left) and BPMV (right)). The coils (seen in the picture on the below, (Figure 2 – Coils) fit over small spools that have valves inside them. The valves are operated by an electromagnetic field supplied by the coils.
Start by doing a quick visual inspection of the wires. If there are any obvious signs of damage, you've likely found the problem. One member had a problem with the wires rubbing the serpentine belt
Also check to make sure the wire harness has a good connection. If the connection appears solid disconnect it (see step 3 in the replacement instructions below) check the pins to ensure that they have not been bent or damaged in any way. If there is any sign of corrosion, clean it off. Once everything looks good, reseat the harness.
Next, let's move on to the grounds. The EBCM is grounded to the chassis on the left frame rail, just forward of the engine. It's the Black box right in the middle of the picture. As you can see, it's real easy for dirt and moisture to get in that area which isn't exactly good for electronic components. Even if you never drive your car in the rain, it'll still get wet when you wash it, and that could be enough
Start by unbolting the chassis ground (Figure 3 – Unbolt Chassis Ground), and then take the chassis ground connector apart.
The next set of pictures (Figure 4 – Chassis Ground Connector 1, 2, 3 and 4) show the corrosion that can build up in the ground connector. If you chassis grounds look like this one, you've probably found the problem. Even if they don't, go ahead and clean it up with a wire brush before putting it back together. Also clean off the chassis and bolt to make sure you've got a good clean ground.
*If you are having any other electrical issues, it's a good idea to check the grounds. These pictures show where the other grounds are. (Figure 5 – Chassis Ground Locations)
It's unlikely, but before you break out you credit card and forking over your hard earned money, it's a good idea to check the fuses. One fuse box is located under the hood beside the battery; the second one is under the passenger side of the dash. Remove the floor mat and you will see the access panel. Just pull the fuses out and do a quick visual check.
On the left, you see a good fuse (Figure 6 – Good Fuse); on the right is a bad fuse (Figure 7 – Bad Fuse)
At this point, we know all of the wires are good, but for some reason enough voltage is not getting to the system. It is possible that your battery is not functioning properly. If your battery is a couple of years old, has been drained and recharged a couple of times it might be a good idea to go ahead and replace your battery. This is a long shot for EBCM issues, but I think it's worth a shot before spending several hundred dollars for a new EBCM and you're going to have to replace it eventually anyways. Old batteries can cause a variety of minor electrical issues and you likely have a bunch of history codes for minor issues if the battery is causing the problem.
Now on the EBCM itself, if the electrical contacts (Figure 8 – Electronic Brake Control Module) inside the relay are dirty or burnt, the vibration from striking the module may change the symptoms or may clear them up for a while. This is by no means a fix or a cure all, in fact it could make it worse or it may not do anything, it's just something to try. Use a small plastic hammer or something similar; lightly tap the front of the EBCM on the lower right corner of the module. The area will be on the right hand side of the lower electrical connection seen in the picture below.
At this point, you’ve got to additional possibilities. Replace the EBCM or replace both the EBCM and the BPMV. The service manual calls for you to measure the resistance between each pump motor control circuit and the housing of the BPMV, if that checks our okay; you replace the EBCM if not you replace them both. Since most people do not have the equipment to do this the best we can do is to replace the EBCM. If that doesn't work, you'll have to go back and replace the BPMV. The procedure for replacing the EBCM is very simple. The only special tool you need is a T-20 Torx screwdriver.
I have a Craftsman tool set that has a 1/4" drive screwdriver with and adapter for many different size bit. Unfortunately, the adapter was too long to fit between the EBCM and water pump, so I purchased a set of Craftsman 5 pc. Torx screwdriver set that worked fine. A flathead screwdriver may also be needed to pry apart the EBCM from the BPMV
1 - make sure the car is off.
2 - You will probably need to remove the air bridge to get to the EBCM.
3 - Remove the wire harness by first removing the white plastic clip that locks it in place (I cut it off and replaced it with a zip-tie) (Figure 9 EBCM (Left) and BPMV (Right)), then lift gray handle and pull back on the wire harness (Figure 10 – EBCM Disconnected (Front View)). At this point, you will be able to see the second wire connection that is removed by pulling down EBCM. (Figure 10 – EBCM Disconnected (Front View))
4 - The service manual calls for you the remove the 2 insulator nuts that hold the BPMV to the brackets and lift the EBCM/BPMV out of the bracket. I do not think this step is necessary because there is plenty of room while it is still in the bracket and you do not gain much additional clearance since the brake lines restricts the movement.
5 - Remove the 6 T-20 Torx screws connecting the EBCM and BPMV - 1 on each corner and 2 on the sides (Figure 11 – Remove 6, T-20 Torx screws EBCM and BPMV).
6 - "Separate the EBCM from the BPMV by gently pulling apart until separated" - I should start laughing here, but it's not that funny. It's been my experience that anytime the instructions call for you to do something gently, nothing gentle is going to work. In this case, I had to use a flathead screwdriver to break the seal. Once it moved a little, the rest was easy. In addition to the rubber seal, each of the 12 holes you see in (Figure 10 – EBCM Disconnected (Front View)) has a peg in them from the BPMV. Don't go crazy, but be prepared to force them apart.
7 - At this point, all you've got to do is put it all back together. Push the new EBCM onto the BPMV.
8 - Replace the 6 T-20 torx screws
9 - Reconnect the wire harness
10 - Put the intake back on
At this point, the AH/TC/ABS should work normally. If not, you've also got a problem with the BPMV. Although you could replace the BPMV yourself, you have to bleed the ABS system, which requires Tech II. For those of you like me that don't have access to Tech II, you've got 2 options. Replace the BPMV yourself and tow the car to a shop with Tech II to have it bled, or just take it in to have the BPMV replaced. The advantage is that you've already done all of the trouble shooting so you want have to pay the mechanic to diagnose the problem for you.
Replacement part sources
New EBCM’s … below is a list of part #s. Check with
Fred Beans for actual price & availability ($650 to $1000)
Part Number: 10343433 All 2003-2004
Part Number: 12216561 All 2001-2002
Part Number: 9367071 All 1999-2000 w/o Control Active Brakes
An alternative to buying a new one is to have your original rebuilt.
Old 11-24-2008, 08:35 AM
striper
striper's Avatar
There is also a ground connection on the left frame behind the headlight where you might want to try clening the connections. Eventually you might have to repair or replace the ABS module. Just be a little cautious if driving with it removed, since the ABS will not function. With my typical good luck, during the time of my repair, I had a situation where I had to make a high-speed panic stop. My car kept sliding instead of stopping and I narrowly missed hitting a car stopped on the highway. I guess I was lucky!
Old 12-31-2011, 11:37 PM
spuckie
spuckie's Avatar
I have an 02 and got the same C1214 code. A dealer told me around $2200 (I think). A local mechanic told me $1400. I removed it myself, and mailed it to absfixer yesterday. For such a huge difference in price for the diy, am I missing something...can it be this easy?
Old 01-01-2012, 12:32 AM
02koolC5
02koolC5's Avatar
Yes! it is this easy, a whopping $1.78 for the failing relay....and sometimes it is just a re solder fix. Did mine a year ago myself with the help of this thread >>>>>>>>> http://forums.corvetteforum.com/c5-t...r-fleabay.html
Old 01-01-2012, 12:57 PM
toddk
toddk's Avatar
Me too, but an even more cost-effective $0 by just re-melting the solder using the original relay.
Lots of valid options above if you just want to pull it and ship it off to someone. Otherwise 02koolC5's thread is for the DIY version. Some hammering to get the blasted thing open, and a little soldering. I'd argue the worst part is getting the module out which you'd have to do in either case. Whichever way you go, it should clear the C1214.
Todd
Old 01-17-2012, 05:15 PM
spuckie
spuckie's Avatar
Took the unit out in maybe 20 minutes and sent it to absfixer. Got it back in no time, with updates via email along the way. 20 minutes later, after clearing the codes, problem solved.
I was pessimistically expecting the lights to show back up, but it's been days now and it's perfect.
Cost me $150 plus another $50 for a surge suppression built in. Quite the difference than if I took it to the dealer.
Old 01-17-2012, 06:14 PM
TheFin
TheFin's Avatar
Old 02-20-2012, 04:15 PM
HTWHLS
HTWHLS's Avatar
Hey folks..sorry I haven't been here in a while. The new position has my garage time extremely limited. I'm asking for some help and..patience.
I have this same problem. Get the three msgs: service ABS, Service Traction control, service active handling. This would pop up occasionally and shutting off the car and restarting it would clear it. I detected no problems in active handling or the ABS (both from near misses thanks to a couple of bozos on I-85 in WV!) and took it to the dealer. They're telling me new ABS module for 1528.00 plus labor.
I have a few questions because I believe that ABS Fixer is the way to go but the first steps: (bear with me..I've been in LT1 World working on my Impala and <ahem> my Corvair's flat-six..):
1. I'd like to clear the codes and try driving the car again to see if they reappear. Can you guys recommend a good, quality code reader/clearer? Does the Diablo or Predator allow for this without having to move the new tuning code in?
2. If the codes come back and the messages display and I go the ABS fixer route, should I leave the messages and after reinstalling the repaired module, will the DTC clear the messages?
I greatly appreciate the help! Thanks again the Corvetteforum!
Last edited by HTWHLS; 02-20-2012 at 04:20 PM. Reason: missed some information that was helpful
Old 02-20-2012, 04:56 PM
Trios
Trios's Avatar
Old 02-20-2012, 05:00 PM
dougbfresh
dougbfresh's Avatar
you can clear the codes from the dash-you don't need a reader to do it. You may have a code after you get the module back, clear it from the DIC if you do.
Old 02-20-2012, 05:28 PM
spuckie
spuckie's Avatar
For codes and clearing...
http://www.c5forum.com/ayc/dtcdic.php
Old 02-20-2012, 06:35 PM
Bill Dearborn
Bill Dearborn's Avatar
Received 8,928 Likes on 5,333 Posts
Make sure you are clear on which module they are talking about. The EBCM or the BPMV. C1214 can be caused by either or both of those modules. ABSFixer can replace the relay in the EBCM. Nobody can repair the BPMV.
Bill
Old 02-20-2012, 08:04 PM
Cybermind
Cybermind's Avatar
Another company that you can send your EBCM to is ModuleMaster.com. I just purchased a remanufacured EBCM from them for $250.00. I wanted to keep my original EBCM as a backup. It works perfectly and they gave me excellent service.
I tried getting a remanufactured module from ABS Fixer and they never got back to me for some reason.
Old 02-20-2012, 08:08 PM
dezcapt51
dezcapt51's Avatar
I have the same problem. Took her out in a wet parking lot and slammed on the brakes which engaged the ABS. I spun the tires to engage the TCS cleared the codes co far so good. I read on the forum they get stuck from lack of use.
To ABS module question
Old 03-04-2012, 02:16 PM
HTWHLS
HTWHLS's Avatar
Originally Posted by Trios
Now that's funny!!
Old 03-04-2012, 02:19 PM
Trios
Trios's Avatar
Old 03-04-2012, 02:28 PM
HTWHLS
HTWHLS's Avatar
Bill
Thanks Bill, and everyone. I have checked and confirmed the codes (thanks for the repost of that process). I also have the estimate from the dealer with the numbers and I have the same code as noted C1214. I am going to see if I can get the part out today. I am also going to check the grounds while I am in there and replace the battery since this problem also seems to be draining the battery. I don't drive the car much since its actually for my wife and it spends a good portion of its time as "garage jewelry."
I appreciate all the help people. As you can see from schedule, I'm only getting back into this thread today..two weeks later. Will let everyone know how I make out.
Quick Reply: ABS module question
