How to remove door panel??
Old 11-16-2008, 04:09 PM
dbfrdan
dbfrdan's Avatar
Default How to remove door panel??
Does anyone know how to remove the drivers door panel. My window is making a crunching noise as it rolls down
Old 11-16-2008, 05:09 PM
BanditDude
BanditDude's Avatar
This is the reference I'm using. Good luck.
link
Old 11-16-2008, 05:55 PM
Bakersfield
Bakersfield's Avatar
This will help you.
http://forums.corvetteforum.com/c5-g...w-problem.html
Old 11-17-2008, 12:12 PM
TEXHAWK0
TEXHAWK0's Avatar
I found that even the tools made for removing the panel fasteners are too thick to fit between the panel and the door without marring the edge of the panel.
I just used a heavy duty putty knife, put masking tape along the panel and door next to the fasteners, and used patience.
The hardest part of removing the panel is to get the nylon fasteners to release without breaking anything. There is a tendency for the panel to break where the fasteners snap in if you are not careful.
Once you get the panel off, and remove the glass, changing the window regulator assembly is easy. Just a matter of removing the mounting bolts at the ends of the regulator rails. Before you remove the glass, put masking tape along the weather strip along the outside of the door at the top, and mark the vertical and horizontal position of the glass. It will make it a lot easier to get the glass back in the opening exactly where it was when you put things back together.
Old 11-18-2008, 11:31 AM
94legaleagle
94legaleagle's Avatar
I've done this before, but windows need adjusting, so I'm "bookmarking" this page
Old 11-18-2008, 12:48 PM
The Wrench
The Wrench's Avatar
DANGER, Will Robinson!
Do Not, under any circumstances try to pry up the window/lock switch panel! Wait until you have the door panel loose, and just push the panel spring tab out from the back. Ask me how I know.
The spring tab, by the way, is on the rear of the driver-side switch panel, and on the front of the passenger side. But, if you reach in there under the end of the panel with a prying or pulling device, you can break the switch panel - and these are pretty expensive.
I know some have probably done it many times, but do you feel lucky?
DG
Old 11-05-2010, 06:40 PM
waterprez58
1st Gear
waterprez58's Avatar
Default door panel remove C5
this is a very detailed (pictures included) removal page.
http://www.vetteessentials.com/instr...or_handle.html
Old 11-05-2010, 07:13 PM
imavettegirl
imavettegirl's Avatar
first two links say i do not have access privileges.
anyone else having trouble?
Old 11-05-2010, 08:25 PM
DAV162
DAV162's Avatar
Me too
Old 11-05-2010, 09:06 PM
_zebra
_zebra's Avatar
same here
this is the one i used. just be careful unplugging the switches - the plug's pretty tight
Old 11-06-2010, 08:18 AM
guido7834
guido7834's Avatar
Originally Posted by DAV162
Me too
Me three
Old 11-06-2010, 10:19 AM
C5at57
C5at57's Avatar
This one worked for me.
Old 11-06-2010, 01:07 PM
imavettegirl
yep, that one works but the first two do not.
Old 11-08-2010, 09:19 PM
Z06Thunder
Z06Thunder's Avatar
Yep got the same message. What gives?
Old 01-25-2011, 10:02 AM
Army Sturgis
1st Gear
Army Sturgis's Avatar
Im having the same problem, did you figure out what was causing the grinding?
Old 06-11-2011, 09:26 PM
Spectre86
Spectre86's Avatar
getting ready to change out the drivers side window regulator. anyone have any pointers?
edit.
just found this for any people who need help in the future.
http://www.spdkilz.com/techtipfrontspeaker.html
http://www.youtube.com/watch?v=Xm1xu-fvZx0
To How to remove door panel??
Quick Reply: How to remove door panel??
