Turn Signels and Flashers
I am having a issue with the turn signals and flashers. Sometimes they will work and smetimes I get nothing. Any idea where to start. We they are not working I don't even get a light. When they want to work they work perfect.
I have the same problem. It is very confusing. Nobody seems to have a clue. The strange part is I can turn them off, wait a few seconds, then turn them on again... they may or may not work.
St. Jude Donor '19
Your turn signals run thru your hazard switch,You need to replace hazard switch.It will cost about $40.00 and take around a hour to do.At the top of the page is the ultimate DIY page,Thats were you"ll find the directions.Good luck!
here is a link to the simplified approach DIY..
the othe rone invilved removing the dash pad...
http://myweb.cableone.net/kd5fx/HSwitch/HSwitch.htm
http://www.corvette-enhancements.com/c5_flasher_fix.php
Get this part from Richard and be done with the flasher module
