Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-16-2008, 03:30 PM   #1
claysmoker
CF Senior Member
St. Jude Donor '09-'11-'12-'13-'14
claysmoker's Avatar
Default LS-1 double overhead cam engine?
Supposedly these were made for some kind of one-off racing class in a Cobra body, and supposedly GM built them.
I have a chance to buy one cheap, and I need whatever info I can find.
Thanks, Dave
claysmoker is offline   Reply With Quote
Old 10-16-2008, 03:58 PM   #2
lucky131969
lucky131969's Avatar
Send a message via Yahoo to lucky131969
Thanks, Dave
Wow, I've never heard of that. You sure it's not an LT5? In any case, it would be a bastard engine setup.
lucky131969 is offline   Reply With Quote
Old 10-16-2008, 04:51 PM   #3
Shore
CF Senior Member
Shore's Avatar
LT5 is the DOHC engine I know of.I couldn't imagine going from an internal cam to overhead on a LSX block.
Shore is offline   Reply With Quote
Old 10-16-2008, 05:48 PM   #4
byte_me
CF Senior Member
byte_me's Avatar
Interesting...I too have never heard of this and I have read a lot about the design of the LS1...
I read in an LS1 performance book that durning initial testing of the LS1 engine, the engineers put an LS1 and an LT5 (boat motor - 32 valve ZR1 engine) in two test mules and allowed for a field test- although the LT5 @ 405HP showed an increase in power (duh) it was not immediate as was the LS1, meaning the the LS1 made its power lower in the RPM range and gave the engineers a kick in the pants they really enjoyed. Just about all of them preferred the LS1 car despite them not being allowed to look under the hood or knowing what was installed...
Now to my point...
it was after this test that confirmed the direction the LS1 engineers to keep a cam in design regardless of the (then thought) out of cam block design many sports car manufacturers touted as being the best of the best.
I guess to continue to prove this point, they shortly introduced the 405HP LS6 engine and the King of the Hill was no more on its own.
I would guess you have found an LT5 engine...
byte_me is offline   Reply With Quote
Old 10-16-2008, 06:58 PM   #5
blue63cpe
CF Senior Member
Perhaps its a northstar, i've read that the ls1 design came from it.
blue63cpe is offline   Reply With Quote
Old 10-16-2008, 08:06 PM   #6
ArKay99
CF Senior Member
ArKay99's Avatar
2 things to consider.
1: Do you have pictures?
2: Be careful.
If there was a small run of an LS1 of this type I would think if it still ran it would be a: a museum piece, or b: very expensive.
ArKay99 is offline   Reply With Quote
Old 10-17-2008, 01:14 AM   #7
runamuk
CF Senior Member
Cruise-In V Veteran
St. Jude Donor '04
runamuk's Avatar
If there was a DOHC engine built GM wouldn't call it an LS-1 since that title was given to another motor.
runamuk is offline   Reply With Quote
Old 10-17-2008, 09:25 AM   #8
BLOWNBLUEZ06
BLOWNBLUEZ06's Avatar
regardless, I wouldn't touch it. Next thing you know, you'll be wanting to upgrade parts with nowhere to go. Or you'll have technical questions with no one to ask. You'll go to the local parts store for some simple every day item and they'll look at you like you have 3 eyeballs.
__________________
Hsquaredracingengines.com RHS427, custom MAST heads, DP direct drive, and F2, custom fuel system, Moran billet atomizers, Kooks 2", custom BTR cam, RKT56 ZR1 trans, RPM quaife ZR1 diff, DSS shaft, Tilton carbon quad clutch, Haltech Sport 2k. Assembled, installed and tuned by yours truly with the help of Ed Hutchings, Arun
I spend my money on Car Parts and Race Gas... The Rest I waste...
BLOWNBLUEZ06 is offline   Reply With Quote
Old 10-17-2008, 11:53 AM   #9
black98c5
CF Senior Member
black98c5's Avatar
Quote:
I would pass on it.
black98c5 is offline   Reply With Quote
Old 10-18-2008, 10:26 AM   #10
jovette
CF Senior Member
jovette's Avatar
I have an extreemly rare LS1 triple overhead cam experimental engine I'd let go, if the price was right!
jovette is offline   Reply With Quote
Reload this Page LS-1 double overhead cam engine?
Tags
1999, cam, cams, corvette, double, dual, engine, engines, enginw, head, heads, ls, ls1, overhead, twin
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
