Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-10-2008, 02:39 PM   #1
oh1vette
CF Senior Member
oh1vette's Avatar
Default Air Intake - Dual Cone vs Others
Any opinions/info concerning the dual cone type intakes like the link below vs the halltech venoms, stingers or others of that type with the single filter. I like the look of the dual design but how does it compare functionally?
Thanks.
Click the image to open in full size.
oh1vette is offline   Reply With Quote
Old 10-10-2008, 03:42 PM   #2
Dave68
CF Senior Member
Dave68's Avatar
The most important things to consider are:
1) Quality and size of the filter media: Proof of filtering ability? Is its surface area large unough so that vacuum pressure at thethrottlebody is minimized?
2) Cold air: make sure that the filter has access to a cold air stream.
If your system can satisfy those requirements, it should help produce as much extra HP as most other intake systems; it's that simple.
__________________
2001 Mag-Red Coupe 6-Speed, 1SC, Z51, Born: May 17, 2001, delivered June 7th, 2001
315.9 RWHP 337.7 RWTQ (Dynojet) 6/8/02 (no mods)
328.8 RWHP 352.2 RWTQ (Dynojet) 5/22/04 with Halltech Stinger intake and CAI mod
Quad Round Borla Stingers 9/6/03
2002 Z06 airbox, 2013
Cold-air scoop mod 5/20/04
TPS Z06 shifter (replaced BPP on 12/26/11)
Intake install, oil trap, and CAI mod: http://www.conceptualpolymer.com/corvette_c5_corner.htm
Dave68 is offline   Reply With Quote
Old 10-10-2008, 08:57 PM   #3
02gt350
CF Senior Member
02gt350's Avatar
the stock air bridge was flowed and had the same numbers as a halltech...IMO, they are all hype...dosnt add any power I dont think. keep your stock air bridge and get a K&N filter...be the same thing..unless you want the super cool looks of a aftermarket,
__________________
2002 TORCH RED COUPE MN6 HALLTECH STINGER - TI Z06 - B&M SHIFTER - Z06 SWAY BARS - REAR FASCIA BLACKOUT - TPIS LONG TUBE HEADERS - CATLESS X-PIPE - BLACK Z06 WHEELS - 416 (L92-L76) LS3 - T1 GM RACING SHOCKS - TEXTRAILIA Z-GRIP CLUTCH - 4.10 GEAR/HARDENED SHAFTS - DTE BRACE - MCM HOOD - DEPO HID'S
02gt350 is offline   Reply With Quote
Old 10-10-2008, 11:18 PM   #4
Dave68
CF Senior Member
Dave68's Avatar
If you look at my sig (in my post, above), you'll see the gain that can be almost totally attributed to the intake system. I've been to two Dyno Day events and virtually every C5 with before and after dyno runs saw gains of 10+ RWHP. THAT's a great bang for the buck, IMO. Just because the stock airbridge can flow high numbers on a flow bench doesn't mean the stock box isn't less restrictive than an open element filter. The numbers don't lie - an aftermarket intake filter system is the way to go as long as it gets outside air and filters well.
Old 10-10-2008, 11:47 PM   #5
02gt350
CF Senior Member
02gt350's Avatar
Quote:
thats why I said just get a filter
and you dynoed before and after a intake?????????
Old 10-11-2008, 01:20 AM   #6
Dave68
CF Senior Member
Dave68's Avatar
Yes, I dynoed the car as stock and after the Halltech intake system. When you mentioned a K&N filter, I thought you meant a drop-in filter for the stock box. That wouldn't get you much of anything as far as horsepower goes.
Old 10-11-2008, 01:53 AM   #7
99 vett babycar
CF Senior Member
99 vett babycar's Avatar
except for the hype, there's no difference
99 vett babycar is offline   Reply With Quote
Old 10-11-2008, 09:34 AM   #8
AU N EGL
CF Senior Member
AU N EGL's Avatar
Quote:
many doul cone air intakes cause air turbulence going into the tb and actually slow air intake. ie less power
just a good NEW filter on a single cold air intake is about the best you can do.
and dont even bother oiling those oil cloth filters. Most ppl put too much oil on.
AU N EGL is offline   Reply With Quote
Old 10-11-2008, 10:01 AM   #9
BonestockZ06
CF Senior Member
BonestockZ06's Avatar
If your looking for looks, the twin filter is ok, but if your looking for performance, I'd recommend VR first and stinger second.
BonestockZ06 is offline   Reply With Quote
Old 10-11-2008, 10:11 AM   #10
Oldvetter
CF Senior Member
Oldvetter's Avatar
This comes up time after time. I have seen posts where Dyno results show no gain.
I belong to the opinion that cloth/oil filters are bad for longivity of engine. If you oil too much you cause MAF sensor contaimination. The cloth/oil filters DO NOT filter as well as dry paper. Some aftermarket filters don't fit well and allow dirt in engine. Not to mention hydrolocking with some cold air filters in the rain.
I use a 2002 (or later) ZO6 filter cover with a paper filter. This will help early C5's that have a very restrictive filter cover.
Oldvetter is offline   Reply With Quote
Old 10-11-2008, 01:12 PM   #11
Got uid0
CF Senior Member
Got uid0's Avatar
dont bother oiling the filters? are you nuts?
Got uid0 is offline   Reply With Quote
Old 10-11-2008, 01:16 PM   #12
jrose7004
CF Senior Member
jrose7004's Avatar
Jim Rose Jim Rhttp://www.linkedin.com/profile/view?id=89789687&trk=hb_tab_pro_topose
Just get a Blackwing and be done with it!
jrose7004 is offline   Reply With Quote
Old 10-11-2008, 01:33 PM   #13
Dave68
CF Senior Member
Dave68's Avatar
If your filter was designed to be oiled, just follow the directions, let the filter sit on paper towels overnight, and install. I've been doing this for more than 5 years now and not only is my airbridge and throttle body opening spotless, but I've never had any MAF issues, either. If you are really paranoid about the oil and want a great intake setup, get the Callaway Honker. It reroutes the MAF to just before the throttlebody so that the oil has alot further to go before it can reach it.
Old 10-11-2008, 01:51 PM   #14
AU N EGL
CF Senior Member
AU N EGL's Avatar
Quote:
Nope not at all
PPL put way too much oil on the filters. and a new filter is good for many many miles years without re-oiling.
I have two K&N filters. I change them or rotate if or when lots of grass or dirt get on the out side of them. I clean them off.
Also some ppl like the VR, That would be personal choice. Many of us have found this to be good, but not great.
Again a single intake CAI works wonders.
Black wing and Honker tend to be the Better CAI
Old 10-11-2008, 04:57 PM   #15
Got uid0
CF Senior Member
Got uid0's Avatar
Nope not at all
well telling someone not to oil a filter is just plain stupid. The are meant to be oiled not over oiled. That way they catch dirt and the filter starts to do its job. If there was no oil on them you would injest a lot of dirt.
Old 10-11-2008, 05:31 PM   #16
Y2Kvert4me
CF Senior Member
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Support Corvetteforum!
Since many people overfill their crankcases, you probably shouldn't bother putting oil in your engine either.
It's pretty simple really...a gauze type filter needs to be oiled so it's tacky. That is the only way it can effectively filter the small particles that would otherwise pass through the filter.
If you clean the filter properly, you also strip it of it's oily residue, so it must be re-oiled.
Whether or not people tend to over-oil them is no fault of the filter, and by no means a reason not to oil it at all.
Y2Kvert4me is offline   Reply With Quote
Old 10-11-2008, 05:44 PM   #17
AU N EGL
CF Senior Member
AU N EGL's Avatar
Fine believe what you want.
I know what my engine likes, I do take the heads off each winter. Clean, very clean with no carbon build ups
Oil filters come pre oiled. No need to reoil them for several years. That is why I say dont oil them, they dont need the EXTRA oil.
Old 10-11-2008, 05:59 PM   #18
Chevy Guy
CF Senior Member
Chevy Guy's Avatar
Send a message via AIM to Chevy Guy
After market air intakes = placebo mod.
The C5 air intake/filters are not really restrictive.
The extra noise is cool though.
Chevy Guy is offline   Reply With Quote
Old 10-11-2008, 06:45 PM   #19
olefam
CF Senior Member
olefam's Avatar
I may be in the minority here, but I have a dual-cone intake and I like it. I wouldn't for a moment try to tell you that it gives me any appreciable power increase. But neither does it slow the car down. It looks impressive under the hood (in my opinion), does an acceptable job of filtering the air, and flows all the air my otherwise stock engine can handle.
Best wishes.
Glen
olefam is offline   Reply With Quote
Old 10-11-2008, 06:47 PM   #20
Chevy Guy
CF Senior Member
Chevy Guy's Avatar
Quote:
Best wishes.
Glen
There is no better reason to have ANY mod!! Most of the time I think they are worth it for the sound alone.
Reload this Page Air Intake - Dual Cone vs Others
Tags
2001, air, aur, cone, cones, cool, corvette, double, dual, duel, filter, intake, kn, rain, single, turbulance, vette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
