Wheel Bearing replacement
Old 10-11-2008, 10:46 AM
Got uid0
Got uid0's Avatar
St. Jude Donor '17
Default Wheel Bearing replacement
Need some assistance or diagrams if you have them please.
Are timken ok to use? What other parts are needed for a replacement?
Here is my situation if i give a sharp jab turn to the left on the steering wheel the noise i hear goes away. What side of the car would this point to as far as the bearing having an issue?
Old 10-11-2008, 11:07 AM
rws.1
rws.1's Avatar
Timken are a great bearing and many use them.
PM me your e-mail address and I'll forward a word doc to you.
Old 10-12-2008, 05:00 AM
tstar
tstar's Avatar
St. Jude Donor '11-'12-'13-'14-'15
I would recommend replacing both regardless if only one is bad. Chances are the other is close to needing replacing also...
Old 10-12-2008, 05:32 AM
bcartman2
bcartman2's Avatar
timken are great bearings, if i remember correctly the left bearing would be your problem because when you turn left it unloads the bearing and your problem goes away. you dont need anything else to change the bearing, you need to pull the lower balljoint from the knuckel to get at the lower of the three bolts for the bearing assy. it is an easy job onece you get to doing it.
they shouldnt go bad by themselves but if you hit a large pothole or something like that it would cause the bearing to bournell(SP) causing a flat spot and ultimately creating your problem. i am far from an expert but i went through this on my car chasing a problem created by the former owner of my car when he bumped a curb
Old 10-12-2008, 05:50 PM
double-oh-coupe
double-oh-coupe's Avatar
Check out jakelatham.com ... if I remember right he has a good write up on wheel bearing replacements.
I used Timken when I did mine and no problems at all.
Old 10-13-2008, 06:10 PM
Got uid0
Got uid0's Avatar
St. Jude Donor '17
Well i did mine a bit different than the write up but thank you very much for the info.
I found taking off the upper control arm was easier than messing with the ball joints.
To Wheel Bearing replacement
Quick Reply: Wheel Bearing replacement
