Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-09-2008, 05:45 PM   #1
Leo001
CF Senior Member
Leo001's Avatar
Default GM Hot cam bad rap
I have been doing lots of web research on mods for the LS1, it seems the GM Hot cam gets lots of negative reviews. It sounds very aggressive, but appently it dosn't deliver what you would expect based on its sound. Is there any good feedback on this cam? Assume stock heads, and just a cam swap, headers and maybe a LS6 intake (trying to keep costs down) what cam would be most suitable (increase power, limited loss of drivability) and what kind of HP numbers would be expected. Current mods include a B&B catback and a cold air intake,
Car info: 2000 cp 6sp
Leo001 is offline   Reply With Quote
Old 10-09-2008, 06:21 PM   #2
08 ATOMIC-Z
CF Senior Member
08 ATOMIC-Z's Avatar
Send a message via AIM to 08 ATOMIC-Z Send a message via Yahoo to 08 ATOMIC-Z
What exactly are you trying to accomplish with the mods to the car? More RWHP/RWT acceleration. You need to have a plan. If you just throw parts at the car you will spend a lot of money and accomplish nothing. Take a look at the cams from CRANE. They have some great proven performance packages that deliver power without sacrificing drive-ability. You will also need to have the car tuned to take advantage of the cam and the other parts you use. I have a LS1 in my car so I have been where you are now. I did my homework and am very happy with the way it turned out. I have lost no drive-ability and have a fast fun car to drive.
Just incase you were wondering if I had actuly done any mods to my car, see my signature.
08 ATOMIC-Z is online now   Reply With Quote
Old 10-09-2008, 06:40 PM   #3
Finja
CF Senior Member
Finja's Avatar
A custom grind. Any off the shelf cam is going to lack in power in one area or another. There is NO perfect off the shelf cam....everycar is different. You can get a custom grind for $450 and make way better power, have it set up for how you drive, the mods that you have, ect. ect.
Finja is offline   Reply With Quote
Old 10-09-2008, 07:59 PM   #4
Cajun@BER
Supporting Vendor
St. Jude Donor '04-'05-'10-'11-'12-'13
Cajun@BER's Avatar
http://www.facebook.com/pages/Bare-Essentials-Racing-LLC/184456068345907 @beracing
You can get a custom grind from Patriot performance for about $350. There are some proven cams out there that are off the shelf grinds. A 224/228 or 228/228, 228/232 are just a few that have been proven to provide excellent power with great driveability.
Cajun
Cajun@BER is online now   Reply With Quote
Old 10-09-2008, 08:25 PM   #5
FASST LN
CF Senior Member
FASST LN's Avatar
I ran the GM hotcam on my LS1 Camaro.
It did sound nasty...and smelled nasty too! I think that was due to exhaust leaks and a lack of tuning though.
Given the advancement in dependable valve springs since the hotcam was introduced (and I believe the hotcam specs are just carry over from the LT1 days!!) a higher lift cam can now be run that will net you more power than the hotcam will.
I liked my hotcam, at the time. But now that I'm doing a H/C package on the Vette and there are better valve springs that are now available, I've gone a different and higher lift route.
You may want to at least spend $500 on a cheap set of used ported heads when you do the cam since so much of the car will already be apart. That would probably net you an additional 30-rwhp.
__________________
2000 Coupe 475rwhp/424rwtq
AFR 205s milled to 59cc, PAC 1518 Beehive springs, 228/232 .585/.595 113+4, FAST 36# Injectors, Ported FAST 90/90, LS6 MAF, LS7 lifters, 7.4 Pushrods, Kooks w/ cats, ZO6 catback, Powerbond UD Pulley, Vararam, Ported LS6 oil pump, LS2 Chain, Tex Z-Grip Clutch, Tick's Adj Master, Drilled rotors, ZO6 Springs & Swaybars, Bilstein Sports, Hardbar w/ harness, DRM Brake Ducts & Quantum Spindles
FASST LN is offline   Reply With Quote
Old 10-09-2008, 08:30 PM   #6
Finja
CF Senior Member
Finja's Avatar
Where are you getting ported heads for $500?
Old 10-09-2008, 08:34 PM   #7
Finja
CF Senior Member
Finja's Avatar
Quote:
Cajun
I understand completly, but you will not find an off the shelef cam that will provide the power everywhere. That is what custom grinds are for. With the Patriot cams, do you have to tell them the specs?
Old 10-10-2008, 09:27 AM   #8
FASST LN
CF Senior Member
FASST LN's Avatar
I found a good deal on LS1tech for essentially new Patriot 5.3L stage 2 heads for $500 shipped.
I was looking for a used set of AFRs in the $1,500 range, but after several months of looking/waiting I still hadn't found any. This opportunity came up so I jumped on it. They won't be as good as the AFRs, but the price is worth it.
Old 10-10-2008, 11:08 AM   #9
B-Vette
CF Senior Member
B-Vette's Avatar
Personally, I wouldn't waste the money on a cam without a set of heads to go with it - my two cents.
B-Vette is offline   Reply With Quote
Old 10-10-2008, 01:13 PM   #10
Mike94ZLT1
CF Senior Member
Mike94ZLT1's Avatar
Quote:
There are plenty of people who have shown excellent gains going with just a cam and bolt ons. Lots of people with 400+ rwhp. Bang for the buck a cam is one of the best upgrades you can do. Yes, you will see better gains with a set of heads, but do not in any way negate the gains from a healthy cam.
Mike94ZLT1 is offline   Reply With Quote
Old 10-10-2008, 01:40 PM   #11
zeevette
CF Senior Member
zeevette's Avatar
I used a Crane grind- "Z" cam @228/232@112+5 on my Z with TFS heads milled to 61cc. It is no problem to drive in heavy traffic, but even with cats, it smells. The price you pay for overlap. Fantastic mid-range, with no apparent end on top, 477/428 SAE corrected, and 27 mpg highway.
__________________
'02 black/black. LGM headers/cats/X. iForge "Aero" 18/19 combo. Koni FSDs. Trickflow/TEA heads,and HS rockers, MGW shifter.A&A Vortech V3si trim, and A&A COMP blower cam.RPS Twin Carbon Street. Tick master. Diff by RKT56. ECS brace. Pfadt diff brace. Somebody stop me...
<----OLD AVATAR STILL!
zeevette is offline   Reply With Quote
Old 10-10-2008, 02:58 PM   #12
OhioC5
CF Senior Member
OhioC5's Avatar
Nothing wrong with a cam only set-up. Build as your budget permits..... heres cam only.....
http://s5.photobucket.com/albums/y17...rent=011-1.flv
OhioC5 is offline   Reply With Quote
Old 10-10-2008, 08:49 PM   #13
Leo001
CF Senior Member
Leo001's Avatar
[QUOTE=OhioC5;1567417678]Nothing wrong with a cam only set-up. Build as your budget permits..... heres cam only.....
Sounds great, any idea of performance gains you realized from this uograde? Have you noticed a significant gain in power?
Leo
Old 10-10-2008, 08:54 PM   #14
02gt350
CF Senior Member
02gt350's Avatar
there is a 228/228 LSA 111 for sale in used parts section right now. you wont be dissapopinted...perfect street manners, nice lope, and lots more power.
__________________
2002 TORCH RED COUPE MN6 HALLTECH STINGER - TI Z06 - B&M SHIFTER - Z06 SWAY BARS - REAR FASCIA BLACKOUT - TPIS LONG TUBE HEADERS - CATLESS X-PIPE - BLACK Z06 WHEELS - 416 (L92-L76) LS3 - T1 GM RACING SHOCKS - TEXTRAILIA Z-GRIP CLUTCH - 4.10 GEAR/HARDENED SHAFTS - DTE BRACE - MCM HOOD - DEPO HID'S
02gt350 is offline   Reply With Quote
Old 10-10-2008, 09:42 PM   #15
B-Vette
CF Senior Member
B-Vette's Avatar
Quote:
Your right, but when I had mine torn all the way down the tendency is to keep going!
Old 10-10-2008, 09:47 PM   #16
Cajun@BER
Supporting Vendor
Cajun@BER's Avatar
Cam only is fine. Hell I got 75whp with TPIS headers and 228/228 cam on my 2000 A4. Heads only get you another 30-40whp but cost alot more than a cam kit. IMO I would NEVER buy a used cam. New ones are too cheap if you find the right place. PM me for info on deals on cams, springs, etc
Cajun
Old 10-11-2008, 01:57 PM   #17
OhioC5
CF Senior Member
OhioC5's Avatar
[/QUOTE]Sounds great, any idea of performance gains you realized from this uograde? Have you noticed a significant gain in power?
Leo[/QUOTE]
Leo,
I didnt run it prior to the cam swap, but It runs 12.30 @ 112 mph,
1200' above sea level.
Old 10-11-2008, 06:25 PM   #18
Chevy Guy
CF Senior Member
Chevy Guy's Avatar
Send a message via AIM to Chevy Guy
Your car sounds awesome!
Chevy Guy is offline   Reply With Quote
Old 10-11-2008, 08:33 PM   #19
OhioC5
CF Senior Member
OhioC5's Avatar
Quote:
Thanks, I love it. The neighbors dont. Sometimes I push it out in the street before I start it just to try to keep the peace.
Old 10-11-2008, 08:45 PM   #20
chpmnsws6
CF Senior Member
Cajun
Why? With todays hydraulic roller tip lifters cam wear is minimal at most. I've purchased/used one camshaft the entire time I've been doing the LS1 thing, and made the most power on an old left over cam that was laying in the shop. (232/242 on a 111)
chpmnsws6 is offline   Reply With Quote
Reload this Page GM Hot cam bad rap
Tags
53, cam, cams, camshaft, general, gm, heads, hot, hotcam, ls1, motors, patriot, performance, ported, review, tuning, upgrades
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
looking to buy a 1980 with 305,california corvette. JOSKIMAD C3 Tech/Performance 43 03-23-2004 02:48 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
