Need help with transmission
Old 09-13-2008, 05:16 PM
racerx_72
racerx_72's Avatar
Default Need help with transmission
Can any one tell me where you plug the skip shift plug in at are give me a call at (816) 210-0841 I have another problems I need the answer to
Old 09-13-2008, 09:48 PM
itzza427
itzza427's Avatar
It's been a little while,,But as best that I can recall it is on the drivers side about 1/2 way back and 2/3 of the way up on the side of the transmission. 2 wires with a lift up tab (snap on lock tab). lift the lock tab and wiggle the wire cap off the solenoid and snap in the bypass to the wires and secure to one of the tubes or lines in the area. The hardest part is just getting there!
Quick Reply: Need help with transmission
