oil filter
oil filter
Is it necessary to use a Mobil1 filter? Or can I use AC/Delco or something else. Also does WalMart sell the Mobil1 filters?
Re: oil filter (pewter99)
If you can find the Goldline AC Delco, go with that. Otherwise I would use the Mobil 1. I could not find the Mobil 1 at the local Waremart so I ordered it from Shawn at LAPD. Got it in ONE DAY.
:cheers: :chevy :cheers:
I use the ACDelco UPF44 from CAU on the forum. About $8.50 each. You will hear from everyone else that ACDelco has discontinued the UPF44 but that is old info. They brought it back due to demand.
I am still lokking for a wrap around magnet for the filter.
Mobil 1 makes a very good filter, as K&N and others. I would use it if you can get it, or else one of the Delco 44s. Your Chev dealer might have the UPF44.
St. Jude Donor '05
Re: oil filter
You can really use what ever you want. If you want good protection, go with the Mobil 1 or the UPF-44.
Re: oil filter (Sniper168gr)
There is nothing bad about the PF44. the UltraPF44 (UPF44) is SUPPOSED to catch smaller particals but who knowns. There is no requirement to run any brand filter.
Re: oil filter (RedRyder)
C2 of Year Finalist (performance mods) 2019
St. Jude Donor 03-'04-'05-'06-'07-'08-'09-10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
This is what I use. I have eight on hand, but am worried about future supply availablility.
[Modified by ohsixx, 6:42 PM 1/5/2002]
Toronto Events Coordinator
Re: oil filter (97silverbullet)
The manual says PF44. That is what the car came with from the factory. That is what I use. :chevy
