Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-01-2008, 05:49 AM   #1
enigma94
CF Senior Member
enigma94's Avatar
Default C6 Z06 brakes on a C5 z06?
I did a search and came up with a bunch of threads about rim spacing and offset but I could never find out how easy the swap actually is. Do the C6 z06 brakes directly bolt up the the c5? Also is there a specific offset you need to have for the front wheels for the brakes to fit? I'm running a 18x9.5 +47 (or 57 cant remember) C6 Z06 replica wheel, will these work? Also whats the going rate for the full c6 Z06 brake set up??
TIA!
enigma94 is offline   Reply With Quote
Old 09-01-2008, 09:09 AM   #2
SR-71
CF Senior Member
SR-71's Avatar
The swap is an easy one. The calipers and rotors are a direct fit with no mods, if your using stock brake lines they'll need minor clearancing. I'm not sure about wheel offsets and prices vary. Watch the C6 classifieds for used stuff or check with a corvette recycling business for the best deal.
SR-71 is offline   Reply With Quote
Old 09-01-2008, 06:46 PM   #3
enigma94
CF Senior Member
enigma94's Avatar
Thanks! Anybody else have any idea on the offset clearance or average pricing for the set up?
Old 09-01-2008, 06:52 PM   #4
NIKDSC5
CF Senior Member
NIKDSC5's Avatar
Send a message via AIM to NIKDSC5
I run ace slick 54mm up front and something like 62 or 3 urrr... dunno in the back as if that matters cause the stock speedlines will clear the rear calipers. The only other thing I did was bouhgt some c6z ss lines paid near 1000$ for my rims.
NIKDSC5 is offline   Reply With Quote
Old 09-01-2008, 07:12 PM   #5
69
CF Senior Member
Cruise-In VI Veteran
69's Avatar
Quote:
I Too have the Z07 Wheels, 18's on all four coners, got them from Nate at Corvette Garage (Forum Vendor) and the C6Z06 brakes fit great behind these wheels
K
69 is offline   Reply With Quote
Old 09-01-2008, 07:14 PM   #6
enigma94
CF Senior Member
enigma94's Avatar
^^ From what i've read people who have bought C6z brake lines have had issues with them sealing because they have different fittings on the chassis side from a c5 to a c6, so i'd be very careful with that... You may want to just replace then with c5 SS lines instead to be safe.
Thanks for the offset info though!
Old 09-01-2008, 07:31 PM   #7
NIKDSC5
CF Senior Member
NIKDSC5's Avatar
sealing issues? They are the same line. the c6z lines you do not have to mod that is all. I have tracked the car and put over 3,000 on these brakes and have not leaked a drop.
Old 09-01-2008, 07:32 PM   #8
NIKDSC5
CF Senior Member
NIKDSC5's Avatar
Quote:
K
what are z07 wheels? Do they stick out past the fenders?
Old 09-01-2008, 07:42 PM   #9
SR-71
CF Senior Member
SR-71's Avatar
The chassis side fittings are definitly different on my car. I had Stainless C6 lines and they would only thread in about 2 threads, while the stock stuff threaded way in.
Old 09-01-2008, 07:52 PM   #10
enigma94
CF Senior Member
enigma94's Avatar
You can look it up. There was a post directly from stoptech stating that they were different and that you must order the line for the car not for the brakes because the fittings are different....
Reload this Page C6 Z06 brakes on a C5 z06?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C4 Technical Summary and FAQ - Please Read on a Regular Basis. bogus C4 Tech/Performance 89 09-24-2013 01:59 PM
C5 Z06 Frequently Asked Questions(FAQ) LTC Z06 C5 Z06 Discussion 75 05-10-2013 05:09 PM
C6 Z06 Frequently Asked Questions(FAQ) LTC Z06 C6 Z06 Discussion 56 08-02-2011 02:23 PM
Motor Trend C6 Z06 pics Thud C5 Z06 Discussion 56 01-07-2005 11:10 AM
Do you think the C6 Z06 will be a HT??? Nitrodamus C6 Corvette General Discussion 35 11-03-2003 02:03 AM
C6 spy shots on AutoWeek,com Arnie C6 Corvette General Discussion 279 05-14-2003 08:21 PM
LATEST INFO ON C6/Z06 USCVETTEMAN C5 Z06 Discussion 39 10-15-2002 04:28 AM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
