Review of LG Coilovers, in short: I love them!!!
St. Jude Donor '08-'09
I recently purchased a set of LG Coilovers from my friend Wicked Weasel @ ECS, he upgraded to a set of Penske Coilovers and I jumped at the chance to buy his coilovers since they were practically new and I've seen firsthand how his vette handles both on a roadcourse and on the street. I've been using a set of 04 Z06 shocks and, although they are very good shocks, there were compromises that come with most shock/leafsprings setups. Since I had my vette lowered all the way on stock bolts, the ride was a bit harsh, especially on NYC streets. Worse, I was constantly fighting bump steer (when the steering goes in the direction of the grooves in a worn road), due, again, to the lowered suspension. On the track, they performed very well but I've been doing more and more road race events and I wanted something more.
What a difference!!!! I was kinda scared that the ride would get even more harsh but I had taken a ride in Wicked Weasel's vette and the ride was pretty nice. Well, now that I have the LG coilovers in, I can tell you, it's a dream to drive my vette again!! The ride is still firm and precise but you no longer get that bumpy or floaty feel on less than perfect roads. You can go up to triple digits and not even realize how fast you are going now till you look at the HUD (not a good thing in my case ). The bump steer is totally gone. Wherever you aim the vette, it goes there, the steering feels more precise too. When you hit a bump, especially on turns, the vette no longer feels choppy, without leaf springs, the individual coil spring absorbs the impact and leaves the other wheel alone. Best of all, I was able to lower my vette another inch, I would have had to cut the bushings on my old setup to get that ride height which would have made the ride a nightmare.
I had the vette corner weighted and aligned with the proper camber and toe after the install, I can't wait to see how the LG's perform on the track! Next week, I'm going to Watkins Glen for a road race event, I'll get to really see the difference in suspension then.
Here's a few pics of the install, if you're on the fence on whether to go with coilovers, don't give it a second thought, go for it!!
Up in the air, so long leaf springs!!
LG Coilovers in, they even match my paint.
My old setup. Surprisingly, by going with coilovers, you reduce overall weight. The coilovers are slightly heavier than standard shocks but when accounting for the loss of the leaf springs, it makes up for it. Everyone always wonders why GM just doesn't go with coilovers since most modern Sports Cars use them. Most believe it's because, with a traverse leaf spring setup the bulk of the suspension weight is at the bottom center of the vette rather than at the corners. Alot of coilovers have the spring mounted on the top of the shock which puts most of the weight higher up, LG coilovers have their weight closer to the bottom which allows a more balanced weight distribution.
The LG coilovers are totally rebuildable, using Bilstein shocks, they are easily serviceable as well. In fact, the driver side front nitrogen gas pressure was a little low (you could tell Wicked Weasel really slams on the brakes on those road racing events ), we checked the pressure and topped it off. The valve is easily accessible.
I can't wait to get back on the road this weekend!! If you see a blue vette taking some sharp turns around the NYC area, it most likely will be me.
Alex, can you do me a favour ? can you measure the dimensions on the end of the front leaf spring , like height and width of the end of the spring ? i want to get a rubber hose that would go over the spring and remove the adjusting bolts, as i can not afford the coilovers right now, but would like to get the right hose before i undo my front end to measure. i hope u enderstand what measurement i need.
thanks
- Kons
thanks
- Kons
Do you know if these are similar to the Callaway coilovers? I beliebe they use Eibach shocks, but am not certain. How about cost? Does anyone know how the two brands compare - costwise? I'm thinking about getting a set one of these days and the fact that you have eliminated side-hopping is good news! Thanks for the review.
Is your coilover hitting your tie rod in the back? By the looks of the picture it most be close or hitting. I had problems when I tried coilovers.
thanks,
Steve
thanks,
Steve
In the pic, it looks like it but there was a tiny bit of space between it when it was up in the air. When we set it on the ground, I looked and there was enough space. I've heard no squeeks or anything else that would lead me to believe they are hitting and Wicked Weasel who had them for a while didn't have any problems with the LG coilovers hitting the tie rods either.
thanks
- Kons
thanks
- Kons
I'll find out for you.
Those sound awesome Alex. I remember you saying how much you wanted them when we were talking at Heavenly. I recently did the Pfadts (also got a good used deal ) and LOVE the improvement. Plus I still daily drive my car and find the coilovers just as easy to live with every day. Even the lowering hasn't really made the car any more difficult to drive. I just enter parking lots slower now.
Got any obligatory cool pics of how your car looks ridin' low?
St. Jude Donor '05-'08
Alex glad everything worked out for you.
I ran the LGs for a little of a year and wanted the next level so went with Hardbar Penske Coilover system which is unbelievable, but I never had an issue with the LGs on the street or on the track.
Many ECS cars now have the pfadts and they are really good too, but at the time I bought my LGs the pfadts were not yet proven. Not sure which I would go with now, but probably the one I get the best deal on.
Many people think that coilovers are too harsh for the street, but I found them to be really a nice ride on the street even these northeast pothole filled streets.
