Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Tech
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace Sponsored by
Karl Chevrolet
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-18-2008, 04:44 PM   #1
Canada204
CF Senior Member
Canada204's Avatar
Default 19 inch Drag Radial?
I have 18s 19s wrappd in pirellie rossi tires my rear tires need replacing soon. I am going to have over 550rwhp soon is there a drag radial for 19 inch rims? Or a better tire with more grip?
Canada204 is offline   Reply With Quote
Old 08-18-2008, 06:20 PM   #2
Andrew@MarylandSpeed
CF Senior Member
Don't believe that anything exists yet. Nitto does a 20", but that's the only thing I've come across bigger than an 18" diameter.
Andrew@MarylandSpeed is offline   Reply With Quote
Old 08-18-2008, 07:09 PM   #3
Drewstein
CF Senior Member
Drewstein's Avatar
Quote:
I run a 19" Hoosier R6 on the back of my vette. Feels at least as good as my old 315 BFGs.
__________________
'07 TT LS7 1073rwhp 965ftlbs 18psi
Drewstein is offline   Reply With Quote
Old 08-18-2008, 07:53 PM   #4
CF Senior Member
Quote:
Good info! Wouldn't have imagined Hoosier making a 19" tire!
Old 08-19-2008, 10:55 AM   #5
Canada204
CF Senior Member
Canada204's Avatar
Great info are these tires okay for a daily driver well a weekend driver? How do these things wear faster the a normal tire? Is this tire good good for traction outa the hole? Stock drivetrain are things going to start to break? Do 315s fit on c5z?
Old 08-19-2008, 03:07 PM   #6
Drewstein
CF Senior Member
Drewstein's Avatar
Quote:
Well I'm running L5s so I get the 345/30/19 and I would expect 5-7K miles out of them if you're not doing useless burnouts.
They have 295/30/19, 315/30/19, and 315/40/19 for non-L5 vettes. I don't recall what sizes of these you're supposed to have as my 315s were on an 18" rim before I got the 19s & L5s.
Seeing how they cost $758 a pair on tirerack.com, that's $1516/year to daily drive them using average annual mileage. Is traction that important to you? I know I can spin any non race tire at over 100mph so in my case I spend that money as insurance. I also don't DD my vette and it's never been in the rain.
These tires will get you killed if you drive in anything but dry weather. You're starting to get to the point where you make the decision of best dry traction possible and no wet traction at all, or all around tires like the PS2s that I can spin at 100mph and maybe end up in a wall.
Yes it will stick out of the hole when warm, but you can over power them like other DRs so they should spin before you break anything. You're not going to hook up a 5K clutch dump which is good since that's where things go boom.
I recommend any DR over the run-craps as they will add years to your drive train. Why? Because they won't hop like a solid compound tire will. I have seen several stock power C5s break parts due to wheel hop. The DRs tend to rotate on the pavement without hop. Be careful at the track as rubber on rubber (laid down patches on the track itself) can hook, release, hook, release creating a "hop" effect still.
GL and drive safe.
__________________
Old 08-19-2008, 04:15 PM   #7
cmb396
CF Senior Member
CI 7-8-9-10 Veteran
cmb396's Avatar
I'm in the same boat...
Toyo makes an R888 tire in 19" sizes, it is a competition tire, but in r compound. Several guys in the FI section run it with great results. I think they are the cheapest for that type of tire too!!
cmb396 is offline   Reply With Quote
Old 08-20-2008, 06:39 AM   #8
Warp Factor
CF Senior Member
Warp Factor's Avatar
GL and drive safe.
My Nitto drag radials will wheel-hop on the street or the track, just like regular tires.
Warp Factor is offline   Reply With Quote
Old 04-21-2009, 04:21 PM   #9
Canada204
CF Senior Member
Canada204's Avatar
Is there a reason you use the R6 VS the A6?
And what tire size should I run the 315/30/19 or the 315/40/19
Old 04-21-2009, 04:29 PM   #10
felo357
CF Senior Member
Support Corvetteforum!
felo357's Avatar
felo357 is offline   Reply With Quote
Old 04-21-2009, 06:07 PM   #11
Drewstein
CF Senior Member
Drewstein's Avatar
The A6 is for qualifying where the R6 is for the race itself. This means the A6 gets real hot real fast but is done in a hurry. The R6 will behave more like a street tire, taking longer to warm up and lasting longer.
Depending on what you're running up front, I would run the 315/30/19 as they're 26.4" tall which is pretty good for a C5.
Reload this Page 19 inch Drag Radial?
Tags
19, 19inch, 3153019, c6, corvette, drag, drewstein, inch, nitto, radial, radials, rims, tires, wheel, wheels
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Looking for drag radials to fit a 19x13 wheel hbrumfield C5 Forced Induction/Nitrous 17 07-15-2005 11:09 PM
My 421cid LT5 IS ALIVE AND WELL!!!!! NITROUS JUNKIE C4 ZR-1 Discussion 196 04-10-2005 10:53 PM
What problems could I run into doing this??? TANGLVR C5 Forced Induction/Nitrous 13 01-14-2005 07:55 PM
Who is Making Big HP With Stock Fuel pump? 3XBlack6spd C5 Forced Induction/Nitrous 46 01-03-2005 09:05 PM
Z06 WHEELS 20" AND 19 " FACTORY STYLE OR MOTORSPORT WestCoastCorvette C5 Tech 30 04-22-2003 07:11 PM
Whats the largest stickiest tire for 18x13 rim without tubbing for C5? Mopar Jimmy Wheels & Tires 9 03-05-2003 01:44 AM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
